Oil pump gear one tooth off from factory...wtf?
Old Apr 11, 2010 | 02:14 PM
iTune's Avatar
Originally Posted by Timmay81
i was 1 tooth off on mine , unless it was 180 off plus 1 tooth cause i could spin the belt around 3 times and it would go all the normal place but just 1 tooth off where it should of been
Sounds like it was 180+1, IMO.
Old Apr 11, 2010 | 02:19 PM
Timmay81's Avatar
reason im pretty sure it was only 1 off is cause when i got everything else tdc that gear was the only one not on the mark being 1 tooth off
Old Apr 11, 2010 | 02:34 PM
iTune's Avatar
If it was 180+1 tooth off, it would look the same. The only way you could tell, is if you took a screwdriver and ran it into the balance shaft hole on the side of the engine. The counter weight should be on the bottom of the shaft, if it's on top, you can't fit the screwdriver all the way into the hole.
The other way to tell, if if you put the timing mark at 12oclock and let it go. If the gear rolls clockwise, it's 180 out of phase(counter weight on top). If it rolls counter-clockwise slightly, it's in phase(counter weight on bottom).
Old Apr 11, 2010 | 03:53 PM
Timmay81's Avatar
yes i know this, 180 off would put the gear on the opposite side though
enormiss
Lancer Troubleshooting
10
Jul 25, 2016 04:56 PM
xceler8rob
34
Jul 17, 2016 12:57 PM
Jacks Transmissions
Jacks Transmissions
58
Feb 3, 2016 12:45 PM
KevOVIII
18
Nov 10, 2005 08:05 AM
metaphysical
109
Aug 4, 2004 08:42 AM
