HELP!! Wierd Revving issue
Well this is a little hard to explain.
My car has an issue to rev up on its own when i shift gears. For example: I'll be cruising along in second gear, I'll get on the throttle and when i go to shift at say 6K RPM, I'll depress the clutch, let me foot off the gas, and the revs will shoot up anywhere from 500 to 1500 rpm (at times bouncing off the rev limiter).....without me touching the gas....
At lower RPM's it's less apparent. If i shift as say 3500rpm, the Rpms may shoot up 200rpm.
Just wondering were to start with this issue.....could it be a vacuum leak somewhere? or some other issue?
I've cleaned the throttle body cause i thought it could be gummed up...I've checked the throttle cable to make sure that it isn't binding somewhere...and it seems to be fine...
Help
Help
Common I'd say problem, but I think the cars were designed to do it, considering the number of people who report it. It can be tuned out, if you have your car tuned. Much nicer afterwards!
No changes have been made. At one point i cleaned the TB because i though maybe it was gunked up and therefore not closing properly. This seemed to help the problem last year when i did it. But when the problem re occurred this year, and i cleaned it again the problem didn't go away.
All the couplings are tight that i can see. I could see it being the tune except it never happened this bad before. I'm going to look for Vacuum leaks around the TB.
It seems that the issue varies (as was mentioned before) at if shifted at 3K RPMS it may only "blip" a couple hundred RPM's between shifts. But then brought up to 5K+ RPM's it can jump as high as 1500RPM's causing it to bounce off the rev limiter.
Did you solve the issue? I have the same problem right now. I've tried different BOVs but it's always the same.. The only thing that comes to my mind is to re-tune the ECU..
franzcars
Jul 26, 2023 09:27 AM
D-Man
Mitsubishi TC-SST Discussion
May 26, 2020 12:02 PM
