Urgent clutch question. Exedy Stage 1
Old Apr 10, 2010 | 04:44 PM
GG_EVO_IX's Avatar
Old Apr 10, 2010 | 04:50 PM
JJLANCER02's Avatar
get ur money back and buy an act it just like oem but i guess who every u took it to nevery work on a evo so take it some where else before u before chuck start flying out
Old Apr 10, 2010 | 04:55 PM
GG_EVO_IX's Avatar
That would be hard for me to do considering they have the tranny out already.. Like I said before. This is their first aftermarket clutch install.. They have done many oem clutch installs. Would the aftermarket clutch install be like the oem one or is their a difference?
Old Apr 10, 2010 | 05:05 PM
binky's Avatar
Originally Posted by GG_EVO_IX
A shop is installing an Exedy stage 1 clutch on my evo 9. They never did an after market clutch install before. They gave me a call and told me the Exedy splines are different than the oem one. They said that they have to "force" the exedy one in but scared that it might rip/damage the full face plate? Can anyone that HAS installed an Exedy clutch give me some advice. Did they have to force theirs in?
They shouldn't have to force anything on. If it's correct clutch for the car, the install should be as simple as an OEM clutch.
Did you verify that you have the correct clutch? Not just the box it came in, but the actual clutch itself.
-Bink
Old Apr 10, 2010 | 05:09 PM
GG_EVO_IX's Avatar
I thought so. No, I haven't confirmed if the clutch itself is the correct one. Only the part number. I tried calling the company but I guess they're closed already. How do I confirm that the actual clutch itself is the correct clutch?
-Bink
Old Apr 10, 2010 | 05:11 PM
GG_EVO_IX's Avatar
And they said " It will fit but it would take a little forcing to bolt everything up. After I heard that I said "stop doing what you're doing until Monday when I can get some info from the company". Sigh*
Old Apr 10, 2010 | 05:13 PM
binky's Avatar
The clutch itself should have the part number stamped on it somewhere.
According to Exedy's website, if you bought their stage 1 clutch, it should be 05803 or 05803HD, depending on which one you bought.
-Bink
Old Apr 10, 2010 | 05:16 PM
Force-Fed Performance's Avatar
you should not have to force anything to go together on the clutch. We have installed every clutch on the market and recently three exedy single plate clutches and NEVER have a problem with them. As some others said. Check the part number on the clutch and make sure it is correct
Old Apr 10, 2010 | 05:17 PM
GG_EVO_IX's Avatar
Thanks, I'll have the shop check the clutch for the part #
-Bink
Old Apr 10, 2010 | 05:23 PM
GG_EVO_IX's Avatar
Just got off the phone with the shop and none of the numbers on the pressure plate match.
Old Apr 10, 2010 | 06:19 PM
binky's Avatar
Ah! Well at least you have your answer now
-Bink
Old Apr 10, 2010 | 06:24 PM
GG_EVO_IX's Avatar
Indeed, thank you Binky This fourm has always been helpful even if it's something simple.
-Bink
kpt6
Apr 17, 2013 01:12 AM
zasboy
25
Oct 14, 2012 12:44 PM
