Boost Off...Was 26.5 - Now 21.5
Old Apr 16, 2010 | 04:37 AM
metalsaber's Avatar
Originally Posted by sparky
Where are you sourcing the MBC's boost reference signal from, the compressor housing outlet pipe's nipple, or did you "T" into the line that runs from the IM to the DV?
T into. Based on how the car is feeling, the #s are accurate.
Originally Posted by andrewzaragoza
seems like a wastegate issue. maybe its getting stuck in a half open position.
Was what another person suggested. Will check into that today.
Old Apr 18, 2010 | 06:25 AM
metalsaber's Avatar
Just updating the post with resolution. Not sure how this happened, but the wastegate rod was actually in a higher position than it was when I got it installed. So basically the rod cap hole was about 1/2 a hole higher than the pin. I was able to turn it down to 1/2 a hole below the pin. Pulled the rod up to get it on the pin. That seemed to fix my issue. Again, not sure how it could go from 1/2 hole below to above in a month or 2.
Hopefully this might help someone else in the future.
metalsaber
14
Apr 23, 2012 04:35 PM
metalsaber
19
Sep 14, 2011 06:05 AM
metalsaber
Jun 8, 2010 02:42 PM
metalsaber
Apr 5, 2010 03:43 PM
mrfred
11
Jan 4, 2010 08:13 AM
