Education on PTE Turbo's
True PTE has their own center section now.They were using Garrett until they went their separate way about 6 months ago. I have not heard of too many durability problems with the new center section so to call it garbage is not fair. I have a customer coming in next week with a new ceramic 6262, we should be pushing it pretty hard ,it will be interesting to see how it holds up.
i just see pte's blowing up all over the place, journal bearing and ball bearing. i dont see garretts doing it. i personally went thru 2 in about 3,000 miles and there are a lot more people that have issues.
HTA3582 = PT6162
HTA3586 = PT6262
The PT6765 and PT6265, will spool a bit later then the 62 turbine wheel and not really worth it if your looking for faster spool. They are good for high horsepower though
PT6162 Looking around 4800-5000 and the PT6262 looking around 5000-5200 - Spool time can be reduced with different mods, comp ratio, etc.
The PTE Turbo's have there own center section. They use a cermaic ball bearing center section that is oil and air cooled, no water lines like the Garrett.
Thanks!
Michael
HTA3586 = PT6262
Thanks!
Michael
The 6162 is a cast wheel turbo that in NO WAY POSSIBLE could EVER make 740+whp @ 40psi like we just did with the HTA82..
As far as my opinion goes..
6567's - its a 6765 good for 900+whp makes 40+psi at 6000+
6265' - Good for just over 800whp and 40+ psi around 6000+
6262's - Good for almost 800whp and makes 40psi around 5500 or so
6162's - old technology cast wheel turbo about as equivalent as garett standard cast wheel 35r.. wont make 700+ most likely..
The HTA3582 we just ran spools faster than 6262 and makes as much power or more..
The HTA3586 spools around where the 6262 does but makes over 800 no problem..
There is about the best i can offer from the cars i have used all of them on with similar setups..
MIke
Mike
Ill beg to differ on this...
MIke
MIke
How far have you guys pushed the HTA86? Ive seen roughly 800whp, but thats about it. Im curious to see where the limit of those is.
The smaller journal bearing turbos dont seem to last, but the DBB models dont commonly have problems, unless improperly installed or cause by something else. Some will argue, but the guys I usually see that have issues are ones that install themselves at home.
Mike,
Mike,
Mike
Mike,
Mike,
Wow, thats crazy. Ive never used the HTA86, so do you feel the compressor or turbine wheel makes the difference in power potential vs the 6262?
Great thread and info
Am acutally between the 6765 and 6265, so my question is which one well make 600+whp on a DJ with 93oct, and when can you see full boost on both, ofcourse on a built 2.0 engine??
The Rallycross team we work with in Poland likes to run these
http://www.compturbo.com/products/in...&product=CT361
We use Comp Turbo,FP ,BorgWarner and PTE. I think i may have a dyno sheet for the 61mm. Comp is working on some new wheels but their big thing is their aluminum ,triple bearing center section. MAP is using a Comp Turbo on their new drag car (80mm)
