Duel fuel rail setup
we are ''well i am not'' putting you down. u want something simple and effective. you spent money on a dual rail setup ''extra money over a single rail'' you spent money on another set of injectors'' extra money'' you spent money to get it all to work correctly ''extra money'' when you could have saved so much time, money, hassle by going with a single rail and ID2000 injectors.
Besides for the price of the ID's I still paid less for the 8 FIC's that I have now, by a few hundered bucks.
The guy is running a 4088R Turbo and that's why he got the dual fuel rails.
Yes he is one of those guys. That's why he's looking to set the Evo HP record in Colorado.
Josh is looking to make 800+ WHP!!!
With that Turbo setup and E-85, I bet he would max them out!
IIRC the ID2000's hadn't even come out when he bought his 8 injectors and rails through his sponsorship with FIC... so either way he spent less for everything.
What would be the point of selling everything now and going with ID2000 or 2200's when the AEM can control 8 injectors just fine???
Maybe you genius people didn't read the part where he said " I SPENT LESS ON THIS SETUP THEN ID2200's" so why hassle him on his setup?
o come on now. 4 more injectors means, twice the possible leaks, twice the wiring, twice a possible failure. and clearly twice the headache because this thread has been made. he wants a solution to get it running. if he had a more ideal setup this thread would not exist. ''sorry josh just an example'' and a few other things to boot. the more complication you add the more risk for something to go wrong. thats simple math. and things do go wrong. they might not be common but it happens. since when is a gauge fool proof?
I was just doing some injector math and he maybe right that the 2150cc may not be big enough. Here in the midwest they are big enough for anything but in Colorado it may not be. If he maxed out 1600cc on a 35r (700 crank hp) then his BSFC must be around .65 or higher. If he wants 800whp (900 crank) 4088? Then with a BSFC of .65 he would need around a 1900cc injector, if he wanted a nice 80% dutyy cycle. Now throw in the E85 issue of needing 20-30% more fuel depending on target AFR he would be looking at an injector over 2300cc. I still find it hard to believe but it appears possible. Finally he mentioned running VP Import as a possibility and 2100/2150cc injector are not compatible with oxygenated fuels like Import or Q
You guys really don't understand how much fuel you need to add to make up for the thinner air. Which is why I have been so nice.
So once again Thanks for the comments guys and Thanks APM your link it really helped me out and I am about to order the Y's for both feed & return.
Seidelly
Apr 4, 2016 10:26 AM
