Did you resurface your flywheel on your Exedy Twin?
Old Apr 16, 2010 | 03:40 PM
mr.almeida's Avatar
Hey guys I pulled my clutch out today and I caught it just before it went to the rivets. Mike and Anthony @ AWD recommend I buy the floater plates too, which will be in tomorrow with the clutch. Resurfacing the flywheel will be fine right?
Thanks in advanced.
I'm used to 6 puck clutches with stock flywheels, so I'm unsure.
Old Apr 16, 2010 | 03:50 PM
buchnerj's Avatar
My Exedy HD twin came with a new Exedy flywheel. The resurfaced stock one will suffice though.
Old Apr 16, 2010 | 04:03 PM
mr.almeida's Avatar
Yea I was wondering if it's ok to resurface the Exedy flywheel.
Old Apr 16, 2010 | 08:36 PM
KenMasters's Avatar
Yes, it has to be done on an " Blanchard Grinder " whatever comes off of the flywheel surface must come off of the towers. Make sure the machine shop puts a reference mark , for the part is balanced from exedy.
Old Apr 18, 2010 | 02:03 AM
RSMike's Avatar
usually the flywheel is ok to get skimmed, it's the top pressure plate thats dished that needs to be binned and a new one installed
Old Nov 8, 2010 | 01:54 PM
milford's Avatar
bump from the dead...is this true that the towers on the flywheel must be cut down the same amount that is shaven from the flywheel surface?
Old Nov 9, 2010 | 06:33 PM
milford's Avatar
bump.. does anyone have any knowledge first hand here..Do the towers have to be cut the same amount as the flywheel surface.
The machine shop cut my towers down the same amount the cut my flywheel. I am trying to figure out if this is alright.
Old Nov 9, 2010 | 06:46 PM
milford's Avatar
anyone know anything about exedy twin disc flywheels being resurfaced
Old Nov 9, 2010 | 06:53 PM
n2oiroc's Avatar
yes, the towers need to be ground the same amount. if you take .005" off the disc surface then take .005" off the towers.
Old Nov 10, 2010 | 05:17 AM
mrboost05's Avatar
they are correct
I would post a pic and show you but my cars at the shop i got mine done at kunkels and the guy even new that most machinist will no.
Old Nov 10, 2010 | 06:31 AM
black-dsm's Avatar
don't forget to get the clutch assembly balanced
Old Nov 10, 2010 | 07:23 AM
milford's Avatar
yea the machinist did the towers the same as the surface...i didnt even ask him to do it but i guess he knew it was routine to do this..i just wanted to make sure this was normal to do when rebuilding an exedy twin..i always hear of people resurfacing them but no one ever mentions doing the towers as well... thanks for the responses.
Old Jan 29, 2011 | 11:46 AM
nudge120's Avatar
delete
Old Dec 1, 2011 | 01:24 PM
DKC6691's Avatar
Were do you guys live and what machine shop turned your flywheels? No one in the Seattle area will turn a exedy multy plate flywheel
Old Mar 6, 2012 | 09:34 AM
Evo9"Miss Rose"'s Avatar
*bump from the dead..when you guys say Flywheel TOWERS what are you guys Refering too?!?!?
