Trans Install. Want to light myself on fire.
Old Apr 20, 2010 | 06:30 PM
  #31
Drill_Sergeant's Avatar
Veteran: Army
Originally Posted by 1d10t
I would pull it off, and double check the clutch alignment
^^^ this especially if it's not a single disk.
Old Apr 20, 2010 | 07:04 PM
  #32
badev0's Avatar
I was able to get it on like I posted earlier... I had lubed the input shaft and dowel pins, it slid right on!
Old Apr 20, 2010 | 08:13 PM
  #33
WHTEVO's Avatar
I'm sure it's been posted, but don't use the bolts to make the tranny mount up to the block. If it isn't sliding on, something must be slightly off. Pull the tranny back out, make sure the clutch disc etc is lined up properly, then try to reinstall again. Good luck.
Aaron
Old Apr 21, 2010 | 09:34 AM
  #34
Celica2EVO's Avatar
pulling the intake manifold can make a world of difference as far as getting to the rear mount. More work but i can get the trans back in within 2-3 hours. Except the Tilton clutches make a world of difference because they use a solid hub so the shaft slides into one peice instead of lining up each disc.
Old Apr 21, 2010 | 09:37 AM
  #35
Celica2EVO's Avatar
Also if your using an engine lift, there is a hole on the shift linkage bracket where the you can put a quick link and a chain. Makes a HUGE Difference as its a balance point so the trans sits pretty level.
