New TiAL QR BOV flutter
Old Apr 20, 2010 | 09:11 PM
pog0's Avatar
Happens in all gears. I am not sure what RPM, but it happens right around 12-15 psi.
I guess I will try the next spring.
TiAL Sport,
Can I contact you to get a new spring or exchange a spring? Let me know.
Old Apr 20, 2010 | 09:47 PM
project_skyline's Avatar
nvm
Old Apr 20, 2010 | 10:31 PM
JDMevoBOOST's Avatar
Is this under acceleration or are you trying to maintain speed by keeping the gas pedal in the same position?
Old Apr 20, 2010 | 11:36 PM
pog0's Avatar
It is under acceleration, when I boost. Usually this only happens when I am trying to speed up to the normal speed limit of SoCal - 80 or when I try to pass people driving slow.
The only thing I have left to try is a new spring. Hopefully, I wont have to shell out $35 bucks for a spring.
Old Apr 21, 2010 | 07:09 AM
TiALSport's Avatar
spring isn't going to make a difference, you have the correct spring for your application
can you take a video of this? i'm quite sure it's the turbo at this point
this what it is doing?
http://www.youtube.com/watch?v=LvnSg2MJNvU
Old Apr 21, 2010 | 08:28 AM
Spac3clown's Avatar
I am using the 11lb spring.
Old Apr 21, 2010 | 08:57 AM
Interesting...my Synapse doesn't do what's in that video at all. The Synapse seems to have trouble when I am trying to maintain a constant speed. So if I boost to 80mph in 5th and I back off the throttle to about 20% throttle position, that's when my bov starts fluttering.
Old Apr 21, 2010 | 09:38 AM
pog0's Avatar
It may be like that video but it won't do that if I go WOT. It only happens partial throttle around 12 or so PSI. The BOV is awesome at WOT, holds boost and everything. But when I try to pass someone (normal passing) it will start to boost, then flutter somewhat like the video. If I stay on the gas the same way, it will buck back at me and blow off. If I let off the gas, it will blow off and I can get back on the gas.
I will take a video tonight, it may not be the best but I will try.
Old Apr 21, 2010 | 11:53 AM
TiALSport's Avatar
it isn't the bov in the vid, it's the turbo surging
Old Apr 21, 2010 | 12:02 PM
pog0's Avatar
Let's assume it is turbo surge. What is someone with a stock turbo supposed to do?
Old Apr 21, 2010 | 06:50 PM
GTijoejoe's Avatar
Cry...or get a larger T-body that may work.
I actually had the exact same problem on my GTi with the stnd TiAl 50mm... though it happened at 2-4psi 30-40% throttle mostly in 5th gear. Turbo was a t3/t4 50trim... that eventually blew and I got a 57trim with larger exh housing....problem went away.
My issue 100% was turbo surge
Old Apr 21, 2010 | 08:16 PM
pog0's Avatar
I already have a ported throttle body and intake manifold.
I have made sure EVERY clamp is on tight. I don't have the tools to do a boost leak, I should but that is besides the point. The ONLY thing I have changed from when I got tuned (boost leak test done then) is the BOV.
Here are the videos I took. Second one I go through 1st and 2nd, then 3rd. I am on streets so I didn't want to be too loud to attract any attention.
http://www.youtube.com/watch?v=cYPlpmcGotE
http://www.youtube.com/watch?v=FBN6LeRlCxk
Old Apr 21, 2010 | 09:20 PM
Thats surging which in turn makes the BOV do what it does, its like tial said being on the surge part of the compressor map. The simple solution is downshift.
Old Apr 21, 2010 | 09:46 PM
pog0's Avatar
Like I said in a previous post, when I downshift before the turn, partial throttle through the turn... problem occurs.
It happens in ALL gears. I don't think downshifting is a good solution. If other people aren't having this issue, there has to be a different solution.
Old Apr 22, 2010 | 09:16 AM
ravnos04's Avatar
I am experiencing the same thing with the surging of the stock 8 turbo. I am planning on going ETS T3 with prob 6262. Should the surging stop then? Anything that can help mitigate the surging besides the downshifting with the stock turbo?
