reducing spool up time with FP black
Old Apr 21, 2010 | 01:15 PM
PaperClip's Avatar
[QUOTE=JDMevoBOOST;8224328]I strongly suggest converting to E85. I hate to say it because it's been beaten to death but a FP black on 91 is just not what that turbo was meant for. That turbo was meant for big boost 32+ on good fuel. So basically you gave up all your low end to run a black in a budget sort of setup on 91 gas which is quite horrible.
well if 91 is all you got around town and no E85. look into getting a meth injection kit. some hardware stores sell stuff u can use in it.
Old Apr 21, 2010 | 08:47 PM
fromWRXtoEVO's Avatar
There is not a whole lot that you can do other than minor bolt ons(intercooler pipes, air filter, air intake) or spend a lot of money on a stroker or bigger block.
I am sorry to tell you but it is a real compromise, big turbo means lag. You can still minimize some lag with a good tune and perhaps some other enhancements billet compressor wheel.
I owned 17 turbo cars and I knew the answer as soon as you wrote FPblack, that is the main reason why I stick with the HTA Green.
Carlos
Old Apr 23, 2010 | 12:38 AM
mlee25's Avatar
Originally Posted by 1slowassevo
lol both aren't that good..
Any recommended parts???
Old Apr 23, 2010 | 12:40 AM
mlee25's Avatar
[quote=PaperClip;8225456]
So the meth injection kit would help me to regain the low end and gets better?? I dont know any info about meth injection kit....
Old Apr 23, 2010 | 12:48 AM
irishone337's Avatar
Originally Posted by arghx7
why don't you actually drive the car with the FP Black and make up your own mind about it before you start saying it spools too slow? Everybody has their own ideas of what "responsive" and "laggy" should feel like, regardless of dyno sheets
This is probably the best response so far.
But to answer the basic question, the Full-Race manifold and ECU controlled boost will help the turbo spool a lot faster. Also a better blow off valve will help. As a leaking blow off valve can hurt spool time. Opening up the exhaust as much as you can will also help. I'm not sure of this, so don't quote me, but I was under the impression a ported intake manifold and throttle body can help with spool as they do deliver a quicker throttle response.
What cams are you currently running?
Old Apr 23, 2010 | 12:50 AM
BLKCarbonEVO's Avatar
[quote=mlee25;8231972]
No it will not help your lowend. Meth usually doesn't even come on till 10+psi. He was talking about gettting it so you can run 32+psi and really use the turbo for what it is worth! Making mad power
Mikey
Old Apr 23, 2010 | 01:11 AM
mlee25's Avatar
[quote=BLKCarbonEVO;8231983]
Mikey
aight Thanks for the info!!!! but if I put the kit, does it need to rebuild in every certain amount of time??? Im seriously thinkin about to saving my money for the meth kit!!
Old Apr 23, 2010 | 01:12 AM
mlee25's Avatar
I run HKS 272/272 right now
Old Apr 23, 2010 | 01:24 AM
mlee25's Avatar
Carlos
Old Apr 23, 2010 | 01:43 AM
[quote=mlee25;8231997]
Nope. It is fairly simple... It sprays the whole time you are over 10psi (Or whatever your tuner sets it up at) and you usually have a 1 gallon tank in the trunk. Just drive ***** to the wall till you get low on meth, and just refill your tank. You only want to run 100% meth, preferably M1
You should look at upgrading your cams in the future. The HKS 272s are very mild. I swapped in a HKS 280 exhaust and gained 10hp above 6k which I was happy with but they are still not great cams. They are 6 years out dated. You should look into getting a high lift cam like the GSC S2s.
Mikey
Old Apr 23, 2010 | 06:48 PM
Vigman's Avatar
You can also go a bit more agressive on mivec to help spool if not already done.
Cheers.
Old May 12, 2010 | 07:27 AM
robogast's Avatar
do a compound turbo setup ahaha
Old May 15, 2010 | 08:22 AM
fit2.0's Avatar
I think 2.3 stroker kit is best bet but f dont want 2 do a engine rebuild get a hiflow intake with tb and a exaust manifold and if you wanted do sum portin on the head that would help as well. Preaty much anyting that helps flow more air will help. And unless u dont care bout ur motor dont run past 30psi or u will be risking it. Going fast is expensive and unless u want problems du it right.
Old May 16, 2010 | 04:40 PM
mlee25's Avatar
ITs so helpful !!!! I feel like im getting smart haha awsome info
Old May 19, 2010 | 05:16 PM
Erik@MIL.SPEC's Avatar
Hello.
Im replacing my turbo to FP black and I got lil worried about my car.
I heard as you get a bigger turbo, u will get slower spool up... I used to enjoy
with my stock turbo (as u know it starts to pull hard at the low rpm.)
I m so wondering......
To spool the Black like you want, you will need a full MIVEC 2.4 engine build with a 4G64 (preferably on E85).
Check out the John Bradley/English Racing threads on the subject.
