06 MR 2nd gear grind
Old Apr 21, 2010 | 02:45 PM
007WRX's Avatar
Hey guys, I have an 06 IX MR with the 6speed. Car was about 9000 miles and has never been abused. Ever since I got it, second gear has always grinded when going into it from 1 to 2, but never from 3 to 2. Is this a common problem? Anyone have any solution?
Might need a different fluid?
Thanks, Ryan
Old Apr 21, 2010 | 02:47 PM
skyblas's Avatar
what fluid are you using?
and yes, a good transmission fluid will help smoothen the shifting of gears
amsoil would be a good choice if you intend to change the transmission fluid...
Old Apr 21, 2010 | 02:51 PM
turbotboz's Avatar
Check for proper clutch engagement.
http://www.youtube.com/watch?v=vYJxQ...layer_embedded
Old Apr 21, 2010 | 02:55 PM
apagan01's Avatar
MTG GL4 could help a bit with that.
Old Apr 21, 2010 | 03:02 PM
turbotboz's Avatar
Do you have a hot key for inserting this picture. lol (CNTRL + A). Its all over evom.
Old Apr 21, 2010 | 03:07 PM
007WRX's Avatar
As I said, it has 9000 miles on it. Stock transmission oil and engagement its where it should be.
Old Apr 21, 2010 | 04:02 PM
thedru13's Avatar
My MR is notchy in 2nd. I can feel it notch in. doesn't feel like a grind but just not smooth. My trans is freshly rebuilt as well. so less than 5k on it. I am going to try and adjust my pedal to see. I use diaqueen in my trans so all stock fluids. I do have an aftermarket clutch...
vipevo9
Sep 16, 2014 10:48 AM
evo_ik
28
Feb 22, 2013 07:23 PM
kanovic
Jan 28, 2012 02:15 PM
cij911
Aug 17, 2006 08:44 AM
19psi
Jul 31, 2006 04:56 PM
