Need Help - Exhaust Back firing after replacing Spark Plugs
Old Apr 23, 2010 | 10:13 AM
dpacific's Avatar
No SES light, I just did a swap - put NGK Laser Iridiums (IGR7A-G '3106') in now the engine back fires at idle and I get almost a bubbling exhaust sound when I rev it.
Any ideas what I did wrong during the process that would cause this?
Old Apr 23, 2010 | 10:30 AM
andrewzaragoza's Avatar
did you gap the plugs properly? .024-.026 for evo 8s.
Old Apr 23, 2010 | 10:43 AM
dpacific's Avatar
I was under the impressions that the Iridiums come pre-gapped?
Old Apr 23, 2010 | 12:34 PM
dpacific's Avatar
Well it's not the Spark Plugs, I put the stock ones back in and I'm having the same problem.
I'm wondering if I screwed up my coil packs somewhere along the line.
More symptoms are when I turn the A/C on the idle drops and almost stalls out immediately and a more potent gas smell.
Old Apr 25, 2010 | 07:04 AM
dpacific's Avatar
bump
Old Apr 25, 2010 | 01:38 PM
sleepy_rps13's Avatar
Faulty IACV? Same thing happened to me when I turned on my a/c after my IACV broke.
Old Apr 27, 2010 | 07:04 AM
dpacific's Avatar
Turns out I had the spark-plug wires plugged in on the wrong coilpacks. Talk about slapping yourself in the face.
BUT wait there is still an issue, Now the car drives normally but when I drop into neutral and wait at a red light the idle drops crazy low to the point I can't even hear my exhaust. Then It will sort of even it self out after a minute to a normal idle without stalling. I'm going to go back and check to make sure everything is tight but could this be a gap issue seeing as how these plugs came pregapped? I feel like such a newb with all these problems just from plugs
Old Apr 27, 2010 | 08:23 AM
grillpt's Avatar
Did you have the battery disconnected?
Old Apr 27, 2010 | 08:48 AM
dpacific's Avatar
Yes
Old Apr 27, 2010 | 09:14 AM
gsrboi80's Avatar
That would be the reason. The car will need to relearn idle both AC off and AC on.
Common with most cars but really effects driveability in the evo's
I usually let mine idle for 20min after reconnecting the battery but it could take a few drive cycles to be 100%
Old Apr 27, 2010 | 09:59 AM
TommiM's Avatar
Every spark plug made comes pre gapped to something. The question is, is it gapped to what you need it to. Evo 8 should be around .024"-.026". Every iridium plug I bought was pre-gapped, but they were at .031". You can gap iridium plugs safely. They make a special tool that doesnt press against the electrode. carefully measure the gaps of the plugs and see if they are correct.
Old Apr 27, 2010 | 10:18 AM
grillpt's Avatar
^This.
Take it out and do some stop-and-go driving for about 20 miles. It'll be fine.
Old Apr 27, 2010 | 10:56 AM
dpacific's Avatar
Going to take the plugs out when I get home regap them and let the car idle for 20 minutes, I'll report back the results.
Old Apr 27, 2010 | 11:49 AM
T2Small's Avatar
You'll want it to learn to idle with A/C on and off and also with some steering pump effort. Let it idle for about 10 minutes then take it for a short slow drvie with lots of stops. That should solve the remaining idle issues.
Old Apr 27, 2010 | 12:16 PM
grillpt's Avatar
In my experience letting it idle won't help you. You need to get out and drive it, stop-and-go is best.
