Balance Shaft Timing
Old Jul 11, 2010 | 11:45 PM
Dave W.'s Avatar
You paid for the timing belt job, they should do it right. Print this quote and show it to them.
Originally Posted by Dave W.
The front balance shaft is not connected to the oil pump sprocket. The oil pump sprocket drives one of the oil pump gears, the other oil pump gear is attached to the balance shaft, and the gears let the balance shaft spin at 2/3 speed, so the balance shaft is in the correct postion once every 3 rotations of the oil pump sprocket.
I don't know if there's a modern version for the EVO, but here's the DSM guide to changing the timing belt.
http://vfaq.com/mods/timingbelt-2G.html
The quickest way to test this is to pull out a bolt that's hidden behind the turbo and insert a screwdriver into the bolt hole to check for the position of the balance shaft. The crank and cam gear timing marks also need to be lined up first.
Old Jul 12, 2010 | 04:23 PM
4DOORGALLOR's Avatar
Does anyone of an actual picture of the bolt you are talking about?
Is this it?
Old Jul 12, 2010 | 07:33 PM
Dave W.'s Avatar
Yes that's the bolt + hole.
Old Jul 12, 2010 | 07:43 PM
I have the car at TDC and I have the DP removed. I think I can yank that bolt without removing the turbo oil drain tube. The problem is I just gave the car an oil change so.... Will oil come out of that hole if I remove the bolt?
Old Jul 12, 2010 | 09:53 PM
biggie5252's Avatar
No.
Old Jul 12, 2010 | 09:54 PM
Thanks.... I'll be pulling the bolt tomorrow. If it is out of phase does the timing belt have to come off to fix it or is there another way?
Old Jul 13, 2010 | 05:03 PM
So I had to use an open end wrench to back out the bolt because nothing else fit between the O2 housing and the plug but after 15 minutes of tinkering I removed the bolt. As said above no oil came out of the hole. I ended up using a ball point pen to check the shaft position.
When inserting the pen it would only go in 1". This is less than half of the 2.4" it should be so this SOB is out of phase!!! Crap!!!
Old Jul 13, 2010 | 10:35 PM
Dave W.'s Avatar
To fix it you have to partially undo the timing belt. You can zip tie the belt to the cam gears since that's the trickiest part of a timing belt job, but the belt needs to be loose enough so you can rotate the oil pump sprocket.
Old Apr 12, 2011 | 05:58 AM
meltdown's Avatar
Sorry but I just wanted to clarify this. So to get the balance shaft back in phase you do both of these? Rotating the sproket a full turn is what spins the shaft back into phase?
Originally Posted by turbotboz
Here ya go.
"NOTE that there is an easier way to do this. Simply rotate the mark on the oil pump sprocket until it is pointing straight up, and let it go. If the sprocket rotates towards (counterclockwise) the timing mark on the engine, the oil pump sprocket is aligned correctly. If it rotates away (clockwise) from the mark, spin the sprocket a full turn and test again, and it should properly rotate towards the mark now. Now line the mark on the sprocket back up with the mark on the engine. This avoids having to remove the rear access bolt entirely.
Caution: MAKE SURE THE BALANCE SHAFT IS PROPERLY POSITIONED. It is possible for the oil pump sprocket timing marks to be properly aligned, and have the balance shaft out of phase. This could result in a SEVERE engine vibration. "
Travis
Old Aug 21, 2011 | 06:21 PM
Arctic02z's Avatar
bringing this to the top, i just recently did a rebuild and am having very very low oil pressure... would this cause low pressure also? I will be checking it tomorrow but just curious till then seeings how i have put new oil pump, oil filter housing im running out of ideas
Old Aug 21, 2011 | 07:17 PM
barneyb's Avatar
Nope, unless you are asking concerning balance shafts that have been removed. Balance shafts out of time will not effect oil pressure.
TommiM
15
Sep 30, 2014 04:46 PM
Delux247
10
Nov 28, 2012 09:28 AM
D-VO
20
Sep 30, 2010 09:24 PM
binky
Automotosports - Illinois
11
Mar 6, 2010 11:08 AM
draconx
17
Jul 6, 2007 01:50 PM
