Engine works only with Okada coils
Old Apr 27, 2010 | 03:56 AM
Damon's Avatar
Question Engine works only with Okada coils
Please help me, what is the problem?
After my engine has been strokered (2.3, Motec M800, 9.3:1 comp. ratio, 1.4 bar max. boost), the ignition was misfiring as the boost became higher, at about 3000-3500 rpm. Below and above that, it worked well.
We changed everything: ingition coils, spark plugs, fuel pump, etc, checked the cylinder head, etc. Nothing was helped.
Finally we tried the Okada Plasma direct coils, and the engine works perfectly. Changing back to factory coils, misfiring again at high boost. Changing to another factory coil set, same. Okada back - engine is perfect.
Why?
Old Apr 27, 2010 | 04:18 AM
bigric09's Avatar
obviously because the increased spark with the Okadas.
Order a spoolin up COP and be done with the car. You should be using a COP anyway by now. Also tighten your plug gap a little.
Old Apr 27, 2010 | 04:20 AM
mordecaict9a's Avatar
I would say that's obviously a bad set of coils. However sometimes it can be quirky with these cars.
Old Apr 27, 2010 | 04:58 AM
bigric09's Avatar
not if he swapped coils with the same result
Old Apr 27, 2010 | 05:13 AM
gsrboi80's Avatar
Its probably the plug gap as mentioned causing the issue. The Okadas are just making up for it
Old Apr 27, 2010 | 08:03 AM
andrewzaragoza's Avatar
i bet he could get away with the stock coils but with a much smaller gap. but if he has the budget go for a COP.
Old Apr 27, 2010 | 10:01 AM
Damon's Avatar
We changed spark plugs and factory coils as well, tested 3-4 sets. Same problem.
jameswwt
Jan 19, 2013 01:38 PM
Raceghost
Oct 10, 2011 04:34 PM
Kami Speed
41
Sep 28, 2010 01:27 PM
e-autosports
95
Mar 31, 2009 03:41 PM
Gruppe-S
Dec 17, 2007 01:51 PM
