wastegate actuator
Old Apr 27, 2010 | 07:21 AM
eb66's Avatar
wastegate actuator
I am trying to test my wastegate actuator. I know you can do this with a vacuum hand pump.
At what psi is the wastegate actuator supposed to open the wastegate?
Also, are you supposed to be able to move the rod on the actuator when you pull up on it?
Old Apr 27, 2010 | 07:25 AM
BoostINurI's Avatar
Opens at 11psi
Don't pull on the actuator arm...it moves with compressed air
Old Apr 27, 2010 | 09:14 PM
sparky's Avatar
I am trying to test my wastegate actuator. I know you can do this with a vacuum hand pump. At what psi is the wastegate actuator supposed to open the wastegate? Also, are you supposed to be able to move the rod on the actuator when you pull up on it?
I am just curious. Why are you trying to test your WGA anyhow? Nothing better to do? JK
Old Apr 28, 2010 | 07:01 AM
eb66's Avatar
Thanks for the help! And ya I'm testing it out of boredom. I've been troubleshooting a power loss problem for awhile with no luck, and I think its unlikely to be the wg actuator (because I'm also getting knock and misfires), but I might as well rule it out. I might have more than one problem going on here.
def1
Feb 2, 2017 10:34 AM
snow306
Nov 1, 2016 03:46 PM
lancerrally45
May 20, 2016 06:16 AM
jaysonsyl
Sep 28, 2012 04:39 PM
Braydo25
Lancer Aftermarket Forced Induction Tech
11
May 15, 2010 04:41 PM
