wiring IAT for SD....
Old Apr 28, 2010 | 02:21 PM
KTriplett's Avatar
Question wiring IAT for SD....
I can not for the life of me find anything telling me how/where/ect to run these two wires for the IAT. can someone help me out or point me in the driection of a thread or something.
Old Apr 29, 2010 | 12:32 AM
awd2gen's Avatar
The wires get taped into the maf sensor plug. One wire goes to the black wire on the plug and the other goes to the blue/red wire. It does not matter which one goes where. Simple as that.
Old Apr 29, 2010 | 08:47 AM
KTriplett's Avatar
is that really it? if so thats awesome but can anyone confirm?
Old Apr 29, 2010 | 08:55 AM
RunThat's Avatar
confirmed! go do it
Old Apr 29, 2010 | 09:09 AM
Macaroni's Avatar
What awd2gen said is right...
Old Apr 29, 2010 | 11:52 AM
MasterNater's Avatar
Yes, that info is correct.
Old Apr 29, 2010 | 02:50 PM
Kracka's Avatar
This is how mine is setup: https://www.evolutionm.net/forums/ec...e-logging.html
Old Apr 30, 2010 | 11:12 AM
KTriplett's Avatar
is either method better than the other?
as in is running a wire straight to the eco better than splicing into the maf connector?
Old Apr 30, 2010 | 11:31 AM
boostedwrx's Avatar
I'm not even running an IAT with SD.
Old Apr 30, 2010 | 11:50 AM
95630706's Avatar
Yikes. Anyway, you have two choices, the red wire from the IAT sensor can go to either the ACD fuel temp circut (ECU pin 77 on 8's I believe) or you can use the MAF IAT input. The black wire is the ground and you can bolt that right to the intake mani.
When you set up your map you have to specify which input, as the default is the fuel temp circut for most of the pre-patched ROMS.
All in the IAT logging thread and multiple SD set up threads.
saan2112
Lancer Engine Tech
14
Mar 28, 2016 12:10 PM
Jack_of_Trades
Apr 27, 2014 02:01 PM
arpad
Oct 1, 2013 01:58 PM
DagYo369
Feb 10, 2013 12:03 PM
ajstefanacci
Nov 13, 2010 07:17 PM
