Heat protection for oil pain from DP?
Hey,
As most of you know, aftermarket downpipes run closer to the oil pan it seems and can heat up the oil b/c of this; I guess this is not good. What have you guys been doing, if anything, to shield this heat? Some people have wrapped their downpipes w/ stuff like Thermotech heat wrap -- the process seems pretty tedious and might require taking out the downpipe to do cleanly. RMR gives a stick on heat shield to place on the oil pan but I've heard that just melts/falls off? Any other suggestions -- specifics appreciated. Thanks.
Re: Heat protection for oil pain from DP?
Originally posted by doc_evo
Hey,
Hey,
i ordered the DP from Ultimate racing (ultimate-racing.com) with the thermal wrapping on it. Everything is hand made, (mine was actually hand made to order) and comes with a 5 year warantee should anything not work.
Just as a side note, they also sell a test pipe that doesn't trigger the CEL
Thermal Barrier Coating
check out
http://www.swaintech.com/race.html
I've used their Thermal Barrier Coating on my WRX's up and downpipe - awesome stuff!
Will probably use it on the EVO too!
FS[Northeast]: NY: DC sports "Cat-less" 3" downpipe *Like NEW*
MisUnderStood
30
Dec 5, 2016 05:47 AM
