Mikey's LR2.4 MIVEC 10:1 Motor Build
Rockster: I did read through your thread up until the point where you were awaiting the arrival of a new rod. So, don't think that I am totally a worthless Dr. Watson. I will advise as to when I can visit to sample the local microbrews and get a free ride in your beastly conveyance. Be sure that it is on my agenda, dude
9s and 265s. I wouldnt go back to 9.5s for anything less than track duty since it takes alot of work to get them to fit the rear fenders.
My next set of wheels and tires will be 17x9 with 275/40-17 again.
$175.00 http://www.kigglyracing.com/parts/HL...Regulator2.htm
$1.00 discount if you get it from exstreme psi...
Mikey
Mikey
I think JID2 has the biggest current build thread I know of, mine has alot of views but I am not sure on the overall post count.
Mikey
id like to get volks for my next set sometime down the line here.
IT goes right there badass great i can get that part last i just wanted to make sure it did not go on lower half of motor as im done buying parts down there. ill get one next month then.
nice i will look into this once i get a different set of wheels probably in winter time. 275's probably grip incredible.
