Compression Test today 100/120/117/118
Old May 6, 2010 | 07:48 PM
Enzo1089's Avatar
Unhappy Compression Test today 100/120/117/118
Well I did a compression test today on my car, and I read the minimal compression is 138. Mine was 100/120/117/118. How screwed am I, and what are my opinion?
Old May 6, 2010 | 07:56 PM
n2oiroc's Avatar
do the test over and start from the other end first. make sure the battery is charged, the motor is hot and the throttle is blocked open.
Old May 6, 2010 | 07:57 PM
erald01's Avatar
has the car been sitting for a long time??
Old May 6, 2010 | 07:58 PM
GG06MR's Avatar
The bigger issue is that you have one cylinder that's reading considerably lower than the other three. Better get a leak down test done on at least that cylinder, because something is definitely wrong with it.
Old May 6, 2010 | 08:01 PM
Enzo1089's Avatar
I retested all of them in different orders, all same numbers. Motor is warmed up and I had the throttle body open.
Old May 6, 2010 | 08:02 PM
Enzo1089's Avatar
So how bad is it?
Old May 6, 2010 | 08:12 PM
GG06MR's Avatar
So how bad is it?
Could be rings, head gasket, valve seals, etc. Any way you slice it, something's not right.
4RETECH's Avatar
Did you do a wet test? couple drops of oil in the cylinders.
Old May 6, 2010 | 08:31 PM
3gEclipseTurbo's Avatar
if you have big cams it will lower your compression.
Old May 7, 2010 | 02:45 AM
Enzo1089's Avatar
How big of a cam and how much will it drop it. I have some mystery Cam in my car that we can figure out what it is...
Old May 7, 2010 | 02:46 AM
Enzo1089's Avatar
I couple drops of oil did bring up the compression.
Old May 7, 2010 | 05:37 AM
GG06MR's Avatar
Yes, but it should do it evenly on all four cylinders, so that still wouldn't explain why one cylinder is at least 15% lower than the other three.
Old May 7, 2010 | 05:41 AM
GG06MR's Avatar
How much? If quite a bit, then it sounds like your rings are toast in that cylinder.
Old May 7, 2010 | 05:45 AM
buchnerj's Avatar
Agreed. If you put oil in each of the low cylinders and the compression rises a decent amount. It is always the rings. Time to rip her up.
Old May 7, 2010 | 08:54 AM
Enzo1089's Avatar
Ugh
So what are the major draw backs of having low compression, besides needing a motor overhaul...
I'm trying to stay positive and think that having my compression messed up is robbing my power so the car will be faster when its fixed This is correct right?
