Recomendations on spark plugs for my evo ix
Old May 7, 2010 | 10:23 AM
EvoIX505's Avatar
hey wats up i need to change my spark plugs but i dont know which ones to go with wat do you guys recommend?
Old May 7, 2010 | 10:27 AM
jasonn's Avatar
stock iridium unless you're making an assload more power.
Old May 7, 2010 | 10:36 AM
EvoIX505's Avatar
I'm only doing 330whp
Old May 7, 2010 | 10:45 AM
GgreyEVOIX's Avatar
I'm in the same power range, I use the OEM plugs.
Old May 7, 2010 | 01:05 PM
lbcevo's Avatar
OEM plugs are over $65/set. I use NGK Iridium IX, BPR7EIX. As good or better than OEM and $28/set at Kragen.
Old May 7, 2010 | 01:12 PM
o-townFLA's Avatar
Stock...
Old May 8, 2010 | 05:10 AM
GG06MR's Avatar
You have an VIII, and he appears to have a IX, so the BPR's won't work for him.
The OEM Iridium IX plugs are $47 per set here by the way.....
http://www.maperformance.com/evo-vii...ts/index2.html
Old May 8, 2010 | 06:13 AM
bbyevo8u's Avatar
those are not oem ix plugs!!! i tried to get oem plugs from MAP yesterday and they were unable to get them for me?? so i got them at mitsubishiparts.net just talk to Russel he will hook you up with the best oem prices..
http://www.lancershop.com/customer/p...5&cat=0&page=1
Old May 8, 2010 | 06:54 AM
GG06MR's Avatar
Sorry, I assumed you'd scroll down to this listing: "NGK Laser Iridium Spark Plugs / Heat Range 7 (ILFR7H / Evo IX)"
Here's a link to the exact listing of the plugs: http://www.maperformance.com/ngk-las...7h-evo-ix.html
They may be out of them, but the ILFR7H's are the OEM IX plugs.
Old May 8, 2010 | 07:14 AM
bbyevo8u's Avatar
umm those are NOT oem plugs!
Old May 8, 2010 | 07:19 AM
GG06MR's Avatar
Not in an VIII, but both of my IX's came with ILFR7H's from the factory, and it's widely documented to be that case on EvoM........
https://www.evolutionm.net/forums/ev...ead-plugs.html
Old May 8, 2010 | 07:30 AM
dieselmd's Avatar
Yes they are.
Old May 8, 2010 | 07:42 AM
bbyevo8u's Avatar
ok i was looking at the part # Genuine/OE Mitsubishi Part No: 1822A022 from mits web site, i see the item # is ILFR7H so i stand corrected, it threw me off cause of the american box with diff part # different from the japanese mits box but i think your rite they are the same
http://www.google.com/url?sa=t&sourc...urmrbtMjlJzPcw
Old May 8, 2010 | 08:46 PM
GG06MR's Avatar
No worries. Ish happens. I just did a quick google search under the part number, and here are some other places to get the ILFR7H's for under, or at least right around $50....
http://www.rallysportdirect.com/shop...gs-p-3662.html
http://www.amazon.com/NGK-ILFR7H-Las.../dp/B000HDH19I
http://www.turbowholesale.com/produc...productid=9091
Old May 8, 2010 | 08:51 PM
buchnerj's Avatar
+1 Stock Iridiums (ILFR7H), unless you are making a boat load of power and running hot, then consider the step colder plugs.
