stock crank strength
ok guys as u all already may know im running :
evo 9 MR JDM with:
Precision Billet 6265 turbo with full race twin scroll manifold and downpipe,
1200 cc injectors.
Haltech Sport 2000.
with urz advise i have changed my valve spring and retainers with GSC S2 MIVEC Cams already,
just wated to kno im thinking of changing my stock pistons and rods,
how strong is the stock crank as im not changing it, im putting wisco pistons and man manley rods only.
with these im also putting new ACL main and bearing and thrust washers,
does the crank have to balanced again on removal??? and how strong is the stock crank will it be fine on 2.2 bar boost??
evo 9 MR JDM with:
1200 cc injectors.
Haltech Sport 2000.
It shouldnt have to be balanced since youre not altering the crank. I think that rod bolts are the weak part in an OEM bottom end. Lots of torque will stretch them and then youll slip a bearing.
The weakest part of the stock rotating assembly is by far the rod bolts. Get some arps. If you are taking the rotating assembly out of the block you should have it balanced. The factory balance margin is much greater than would you will get at the machine shop.
In addition when you balance your rotating assembly it helps to focus the force of the combustion on the center of the crankshaft. This prolongs your engine/bearing life.
thanks boss
Factory cranks are well balanced from the factory. The balancing that is needed is the rods and pistons, and the rotating assembly as a group. With your setup, I'd not be relying on stock factory rods or pistons. While you have it apart, replace them with forged parts.
i am changing my internals i.e: wisco pistons and man manley rods, arc bearings, as i have written in the start.
roni4g63
Mar 6, 2016 03:29 PM
CT9A PR
Dec 11, 2015 07:17 AM
desiromeo812
Dec 10, 2015 03:37 PM
Perk77
Aug 28, 2008 07:59 PM
