high hp guys... O ring head or the block??
I kid you not. I'm also getting the L19's and a new head gasket when I start pushing ~40PSI or more. I may not need these things but I'll be the one laughing when your blow your motor (I won't really be laughing, just a figure of speech). I figured it to be cheap insurance to o-ring the block too.
Originally Posted by Wikipedia
Because the pressure in the cylinder must not go too high to avoid detonation and physical damage, the intake pressure must be controlled by venting excess gas. The control function is performed by a wastegate...
I'd say it depends on who is building your motor and who is tuning it.
Its a nice safety net in case you find yourself with some unforeseen knock at high HP. Buschur also uses regular ARP's on his O-ringed heads IIRC.
I O-ringed my head at the last minute, just to be safe. If I had to do it again, I'd O-ring the block instead. Having to resurface the head after it's been O-ringed may be a problem in the future, who knows.
All you guys are taking what JohnBradley said as a reason not to get your block o-ringed. But what you didn't hear was JB said they only _recently_ figured out ways to deck and surface the head and block so they don't need to. So unless you are getting your block and head prepared by ER, I wouldn't consider his advice as saying you don't need o-rings.
