high hp guys... O ring head or the block??
Sorry to bring an old thread back, but are there any other big hp guys with opinions on this? I am debating on whether to do this to my block or not. It is a big hp build running alot of boost (50psi+) with a big turbo. I didn't have sealing issues before running about the same boost. Thanks for any info.
Aaron
Aaron
What fuel are you running 50+psi on? I was told by my engine builder that an o-ringed BLOCK is not necessary for what 99.99% of evo owners do. I'm running 45 psi on c16 and no o rings. Perhaps if you are running methanol and 60 psi, you may need to readdress the issue, but if that is the point you are at, I would recommend listening to your engine builder, who is hopefully VERY reputable, and not the forums.
The o rings do not sit flush with the surrounding surface. Not sure if ethanol is capable of 60 psi...not 85% anyways, maybe 98%. Not to go off topic, but your going to need a very serious fuel system to handle that much ethanol at those boost levels. Have you built an engine before? Hopefully you know what your getting yourself into.
I think you all missed the question.
He asked if he should o-ring either the head or the block not IF he should o-ring it.
I'd do the block if its all out. I think when people do the head its because it's easier to remove to send away to machining.
No they protrude above the block deck slightly, then crushed by the head when torqued. I am sure if you had to resurface the block deck, that you could just re-do the o-ring groove to how deep it needs to be at.
Aaron
Aaron
Aaron
If they protrude wouldnt it make sense to add a recieving groove in the head for an o-ringed block? idk, maybe im over thinking this thing.hah.
They are designed to crush/cut and make a better seal...but yeah, I would want to have a receiving/female groove on the mating side as well.
On my old L28, which was an I6 cast iron block with aluminum head I opted to o-ring the block. You are less likely to have the block decked as you are the head so going the block route allows changes to the head without affecting the o-ring.
We used SS piano wire that was raised above the deck by ~0.010" and was cut to seat into the stock head gasket fire ring. I like the o-ring route because you can utilize a stock head gasket, which is often better for sealing oil & water passages.
5LEEPERISAH23I
31
Nov 20, 2013 08:39 PM
djikonatx
May 18, 2011 10:16 AM
