87mm block o-ring questions
I'm after some guidance on o-ringing my 87mm block for use with a factory 4g63 head gasket over-cut for the 87mm bore.
Not too sure what to do since there isn't much fat between the bores.
Do I do put individual rings around each bore or use a figure 8 pattern?
How far in from the cylinder wall do I get the grooves machined if individual rings are used?
Which part of the gasket are the rings meant to make contact with?
Please only respond if you have experience in doing this!
Cheers
Kelvin
Cheers
Kelvin
Thanks for that! Really appreciate it!
Just waiting for my torque plate to arrive so I can get the machining done and needed to know what specs I should be using for the o-rings.
Not really much local help in these parts when it comes to that sort of thing.
bigturboevo03
41
Feb 11, 2017 09:57 PM
Scottr126
Apr 13, 2015 09:59 AM
djikonatx
May 18, 2011 10:16 AM
