car overheats under boost...
Old May 19, 2010 | 05:56 PM
evo4life400's Avatar
hey guys so my tuner emailed me back and said that the car wasn't knocking, but under boost it was getting very hot and when he tried to add more boost it would get hotter....i know i have a thread right now about knock and i do still get the flashing check engine light but can that also be from the engine overheating?
Old May 19, 2010 | 06:27 PM
dreyfus14's Avatar
Sounds like the timing is too aggressive or the head gasket....also be sure the fan is kicking on
Old May 19, 2010 | 06:30 PM
i will make sure the fan is kicking in but i will have to bring it to my tuner for the timing issue....my car never overheats though even when i punch it...my gauge is always perfect.....im just so confused here and i hate when my car has issues
also there is no oil in my coolant and i just changed the oil today and it wasn't milky at all...the idle is fine and the car is running perfect, but it can't take any more boost and when i punch it the SES light flashes
Old May 19, 2010 | 06:39 PM
dreyfus14's Avatar
Sounds like the tuner has the maps messed up then, do you have a wideband to tell us what the AFR is at under WOT?
Old May 19, 2010 | 06:43 PM
erald01's Avatar
make sure the fans are working, and def get the base map in the car again and see if it will overheat.
Old May 19, 2010 | 07:01 PM
i dont have a wideband but both of the tuners said the AFR's were on the money. the fan is all hooked up and i do see it go on when i turn the air on and stuff....i am going to try and get the logs from my tuner...hopefully he will send them to me!
Old May 19, 2010 | 07:19 PM
RSMike's Avatar
the stock temp gauge wont move from about 80 degrees C to about 115degrees C, so it might have been "overheating" when you were normally driving it anyways.
Old May 19, 2010 | 07:26 PM
Anarchy99's Avatar
Your headgasket is blown. /thread
Old May 19, 2010 | 07:41 PM
well that suck di*k.....can someone direct me on how to replace one
i dont really have the main symptoms though....my coolant is perfect, my oil looks fine and the car isnt overheating...i do get white smoke when the car warms up and i can sort of smell sweet when i turn the heat on
Old May 19, 2010 | 08:38 PM
Hi Im Vinh's Avatar
I agree with this guy , I would suggest and recommend that you get a wideband and a boost gauge( if you don't already have it) ; those two items alone have helped me greatly . I'm sure ur frustrated right now , but stick in there and once the car runs fine again you'll be even more satisfied with it
Raptord's Avatar
Keep checking your coolant level. Mine also has a sweet smell, that's because it's burning coolant. I've got a new head gasket ordered for myself as well. Mine only leaks under boost, which is usually the only time I can smell the burning coolant.
Old May 19, 2010 | 08:40 PM
AWD Motorsports's Avatar
Your headgasket is probably blown.. If the exhaust smells sweet you can be sure of it.. keep an eye on coolant and ill guarantee it is dropping..
Mike
Old May 19, 2010 | 09:20 PM
thanks for the help guys...so i have been reading a little about how to replace it...i need to basically do my camshaft install but take all of the headstuds right out. then take the exhaust manifold off and slide the whole head right up?
this really sucks...if i had the money i would let a professional do it but im broke and just spent the money on a tune to have them tell me they couldnt make any more power and the head gasket might be blown!
Old May 19, 2010 | 09:28 PM
crewdawg130's Avatar
do you have head studs????
Old May 20, 2010 | 06:00 AM
dreyfus14's Avatar
If no headstuds, you mind as well install them while you are there!
