Modifying valve cover with AN fittings
Can AN fittings be welded onto the stock Evo valve cover? It's magnesium, so does that make it a problem?
What size would be preferred? If anyone has pics or tips, please post them up
I want to help the crankcase breath better.
would not weld mag. bad idea. If you a set on doing this drill and tap use a lots of cutting oil to keep heat down. Tap with size you want then use a sealant on fittings.
http://www.jmesales.com/item/103266/...ts-W-PTFE.aspx
this stuff works GREAT. takes super high pressures and pretty high temps.
I drilled and tapped mine. I used a cut off wheel to get the nipples off then a hole saw to make the cuts. Then I got out my 1/2"npt tap and SLOWLY cut the threads. Went to my local speed shop and picked up two 1/2"npt to -8an earls fittings. You will need the hose, catch can, and other misc. fittings also. Good luck.
