best time for oil change?
Old May 31, 2010 | 08:10 PM
dyezak's Avatar
Best time to change the oil?
I like 2:12pm, but that's just me.
Old May 31, 2010 | 08:41 PM
toxic-evo's Avatar
lol, is this random or does something happen at this time?
Old May 31, 2010 | 09:43 PM
sktng22's Avatar
changing oil is overrated
Old May 31, 2010 | 10:04 PM
sparky's Avatar
Originally Posted by cfdfireman1
HOT!!! then the particles of crud are suspended and go out with the oil and don't just lay in the bottom of the pan...
cfdfireman knows of what he speaks.
Old May 31, 2010 | 10:14 PM
BluEVOIX's Avatar
Interesting..
Warm makes sense to drain easier and the idea that loose particles staying up float to drain out. But at the same time leaving the car for a long time, gives enough time to have all the oil from the top of the head drain down so that you remove as much oil as possible.
I just do it after it sits for a little bit and still warm but not hot enough to burn me.
Something to think about...
Aren't our oil filter rated to something around 5k miles? So even though you use some high end synthetic oil that's good for 10-15k miles. Whats the point if the oil filter cant handle it? I just change my oil around 3,000 miles. Sometimes a little over if I dont have time but generally in the 3k mark.
Old May 31, 2010 | 10:26 PM
sparky's Avatar
Exactly! this is why some weirds leave in the long-life oil and just swap on a new filter and top off the oil level.
Old May 31, 2010 | 11:17 PM
wreckless969's Avatar
I do it whe nits hot, after being burned a few times Im pretty good at doing it wihtout getting oil all over myself.
Besides doing it when it hot gives you that motivation to do it precise so as to not need to go to the ER for 3rd deg bruns lol.
Old Jun 4, 2010 | 05:28 PM
barneyb's Avatar
I think oil analysis is more suitable for large trucks were the cost of an oil change is price prohibitive.
I was at a garage and they had oil dry everywhere on the floor. I asked what had happened? The answer was that they had decided to drain the oil out of a Mack Truck. They used a cut-off 55 gallon oil drum to catch the oil. The drum, cut off to knee height had overflowed and covered the floor with oil.
Yeah, trucks hold a lot of oil.
Old Jun 4, 2010 | 05:36 PM
apagan01's Avatar
change at operating temp, warm,,, same for the drivetrain
Old Jun 4, 2010 | 05:50 PM
es850revo's Avatar
cool car.
Old Jun 4, 2010 | 07:23 PM
wizzo 8's Avatar
I found this very funny
