Need Help: Oil Hole on Block
Old Jun 4, 2010 | 07:57 PM
e55nEVO9's Avatar
I apologize for the lack of a better term for it but here's the picture
I need to know what's in that hole I circled. A buddy of mine brought his car over because of a terrible oil leak and cannot figure out where its coming from. Everything on the turbo looked fine and when I removed it, I remembered seeing a bolt in there on my own evo. If anyone knows what goes in there or maybe how long of a bolt needs to go in there i'd really appreciate it!
Old Jun 4, 2010 | 08:13 PM
4RETECH's Avatar
Someone must have forgotten to put the plug back in after checking the balance shaft.The screw is missing , that's all. Put a new one in.
Procedure:
After aligning the timing marks of the engine oil pump
sprocket, remove the cylinder block plug and insert a Phillips
screw driver with a shaft diameter of 8 mm (0.31 inch)
through the plug hole to check that the shaft of the screw
driver can be inserted for 60 mm (2.36 inches) or more. If
the screw driver makes contact with the balancer shaft and
can be inserted for only 20
25 mm (0.79 0.98 inch), turn
the engine oil pump sprocket for one round and align timing
marks again to check that screw driver can be inserted for
60 mm or more. Do not take the screw driver out before
completing installation of the valve timing belt.
Old Jun 4, 2010 | 08:22 PM
TTP Engineering's Avatar
Put a bolt in the hole that it not too long. Use thread sealer.
azinterrider
May 6, 2019 11:42 AM
CeliOnce
May 29, 2015 08:08 PM
shrtstuff89
Sep 20, 2013 01:59 PM
fortyPSIrs
Feb 1, 2013 09:34 AM
Flip
11
Jul 21, 2011 10:51 PM
