p0300 nightmare
Old Jun 2, 2010 | 10:14 AM
SiLLyEVO's Avatar
p0300 nightmare
hey guys, i know theres a lot of threads of the p0300, i get the p0300 code, when im im on the highway at about 3-4k rpms, ....i changed the coils, boots, plugs, cam positioning sensor, and still getting it, i have br9eix in there gapped at about .23---someone recomended also changing the plugs to br8es/bpr8es... i wanna know what else is recommended and if anyone can help me with maybe updating/changing the software on the ecu. i have inspection the 21st on june-2010, so if anyone has a tactrix cable or knows how to block the code, pleasssseee help me---thanks guys
Old Jun 2, 2010 | 10:23 AM
TeStUdO's Avatar
Resonance in the transmission at highway speed sets it off in a lot of cars. Hopefully someone hooks you up and disables it with a Tatrix for you. If not, unplug your negative battery cable to reset the code right before inspection.
Old Jun 2, 2010 | 10:31 AM
gsrboi80's Avatar
Im in NNJ and can disable it for you no problem.
Old Jun 2, 2010 | 11:05 AM
SeeCoryRun's Avatar
i went through this myself, on my 03 all i needed was to upgrade the rom.
hopefully gsrboi can hook you up, GL
Old Jun 2, 2010 | 11:10 AM
gsrboi80's Avatar
I can certainly update him to a 0015 rom which was mitsu's final rom update to try and combat the P0300 issue. It may work it may not. If not disabling it is just as easy
Old Jun 2, 2010 | 11:13 AM
boostedtres's Avatar
had the same problem. was a pre-cursor to the front 02 sensor going out. may not be your porblem, but I had the same thing even after switching plugs. gl
Old Jun 2, 2010 | 01:29 PM
barneyb's Avatar
Get it switched off permanently in the ECU. End of problem.
Old Jun 2, 2010 | 01:39 PM
EvoFredo's Avatar
im still running my stock coils from 03 and i use bpr7es gapped at damn near nothing. .021 it helped alot but i think i remember changing out my front o2 also. i get that code once every blue moon. also im in nevada. hope it helps. bring that gap down a lil more with a hotter heat plug
Old Jun 2, 2010 | 02:25 PM
hitman28's Avatar
via tactrix cable?? or is there another way to crack into it? mine pops up every once in awhile due to cams.
Old Jun 2, 2010 | 02:52 PM
tscompusa2's Avatar
tactrix cable and ecuflash to flash the new rom image to the ecu.
Old Jun 2, 2010 | 03:44 PM
SiLLyEVO's Avatar
gsrboi, whats your number? ill take a ride
gsrboi80's Avatar
That and ECUFLASH only way to do it.
I suppose you could mail someone your ECU
Old Jun 2, 2010 | 03:50 PM
Clutchdc5's Avatar
I went with aem standalone lol just because I don't like seeing the check engine light
Old Jun 3, 2010 | 05:41 AM
TeStUdO's Avatar
Wow, talk about a waste of money.
Old Jun 3, 2010 | 05:55 AM
grillpt's Avatar
You need to run the car though a full drive cycle before the inspection station can read your ecu, that usually takes about 30-50miles. You can't just wipe it clean right before you go.
