precision injectors...
Old May 28, 2010 | 07:26 PM
warpspeedwrx's Avatar
Anyone have problems with the injector insulator cracking. They're the rubber pieces that sit between the manifold and injectors. Not sure if they arent install properly or what. Can anyone confirm if the oem insulators onces will work or not? Theres are precision 780 cc injectors if the size matters. Any words of wisdom appreciated
Old May 28, 2010 | 08:47 PM
turbolarry's Avatar
Mine did on my FIC's, but they are the same (Delphi). Stockers would not fit so I got some Viton seals and they seal tighter the a frog's a$$;
http://www.fuelinjectorclinic.com/cg...-125-6X4-LOWER
Old May 28, 2010 | 08:49 PM
wizzo 8's Avatar
I didn't even use those.
Old May 28, 2010 | 08:53 PM
dubbleugly01's Avatar
you didn't use these!? You must have, or you'd be leaking boost + fuel out under positive pressure and it would be a very dangerous thing!
Old May 28, 2010 | 09:13 PM
jmelocik's Avatar
Stockers work fine on mine. I have several sets of extra seals here as well.
Josh
Old May 28, 2010 | 09:19 PM
buchnerj's Avatar
I have never had a leak with those seals on any set of Precision injectors. I had 3 sets over the years, too. Are you sure the install was clean and they weren't cracked prior to use?
Old May 29, 2010 | 07:49 AM
wizzo 8's Avatar
I just used the o-rings. No leaks
Old May 30, 2010 | 06:32 PM
EVODreams's Avatar
^^^ dangerous
edsct9a
Feb 5, 2016 04:27 PM
09ralliart299
Oct 18, 2014 03:52 PM
jason42003
Dec 19, 2013 05:15 PM
nickyboost
Sep 15, 2012 06:42 PM
TKEVO
Jul 14, 2010 06:08 PM
