need help quick. sparkplugs
my car started missing BAD last night. i thought it could be a fouled plug, took the plugs out and they are toast. i have only had the car about two months and never got around to checking them. the plugs in it are NGK BPR7EIX iridiums. only mods are a 3" turbo back. intake. and boost controller (boost set at stock psi till i can afford tune
) im in utah so 4500 ish feet above sea level. are the 7's the way to go or maybe try a colder set? and what should i gap them at? this is my first time dealing with 4 cyl stuff so i have no idea what they like. its my DD so need some plugs quick!
thanks!
Dave
) im in utah so 4500 ish feet above sea level. are the 7's the way to go or maybe try a colder set? and what should i gap them at? this is my first time dealing with 4 cyl stuff so i have no idea what they like. its my DD so need some plugs quick!thanks!
Dave
thanks!
Dave
Dave
Try any of the following:
BPR7ES
BR7ES
BPR8ES
BR8ES
If you can't find them locally, then try ordering them online from CLUBPLUG.net
BPR7ES
BR7ES
BPR8ES
BR8ES
very funny that i saw this thread. my car starting missing bad last night too and throwing codes. problem is im away on vacay and dont have any tools with me to check the plugs, and its a holiday...awesome. gl with your repair! (also, yes go a step colder if you can find them)
found some bpr8es's somewhat locally. i gapped them at 26 cause i havent found a clear answer on what to gap them at. is that too much gap? at least now the car runs and doesnt misfire now. but i havent gotten on it hard yet.
Hmm, After I let idle for a few minutes and I suddenly step on the accelerator it would misfire sometimes it would sometimes it would not. On the STI a step colder on the plugs was the way to go. Now my EVO is almost stock except for a ARC induction box. It has 48K miles. I just bought it used and I have not checked the plugs yet but I think I should replace them. What is the OEM plug? Aside form the filters what other things do we need to change to do a tune-up?
Sorry guys this is my first time owning an Evo.
Thanks,
Thanks,
Tanman1986
24
Feb 26, 2017 07:55 PM
EVOONYOASS
33
Apr 19, 2006 05:02 PM
