Blow off vavle question?
Old May 31, 2010 | 03:14 PM
boostinggg's Avatar
SCAMMER, do not buy!
I am purchasing a new tial q blow off valve and i don't know what psi spring i need ? I have a fully built 2.0 with a 6262!
Old May 31, 2010 | 03:21 PM
yahh's Avatar
What turbo kit, how much power are you making?
Old May 31, 2010 | 03:23 PM
boostinggg's Avatar
650 wheel and Precision 6262 turbokit
Old May 31, 2010 | 03:28 PM
LGshow19's Avatar
The spring is for pressure release..
Ie.. If your at 25psi and you have a 18psi spring it won't hold boost as well as a 22psi spring and so on.
EDIT: that's for a wastegate actuator....
Old May 31, 2010 | 03:31 PM
boostinggg's Avatar
well the site only lets you choose 6psi-12 psi springs!
Old May 31, 2010 | 03:56 PM
LGshow19's Avatar
My bad I'm thinking about WG actuator..
BOV is still a valve to release pressure.. The stronger the spring to more in will hold..
Old May 31, 2010 | 04:08 PM
Evoryder's Avatar
Bov spring is just for driveabilty. How fast it pulls the piston. Softer spring(less aggressive driving/piston travel) Harder/higher psi spring means it will pull the piston up super fast in vacuum conditions. At WOT the spring doesn't do much.
Old May 31, 2010 | 04:12 PM
boostinggg's Avatar
so what psi spring do you think i should get?
Old May 31, 2010 | 04:15 PM
yahh's Avatar
Do you want it to make more or less sound?
Old May 31, 2010 | 04:16 PM
Evoryder's Avatar
I would say 8psi. Guessing.
Hopefully those that have it can chime in and give feedback on what spring worked for them.
Old May 31, 2010 | 04:19 PM
boostinggg's Avatar
more sound
Old May 31, 2010 | 04:21 PM
yahh's Avatar
So you want a softer spring, 6-8. I would go with either 8 or 9. Your choice.
Old May 31, 2010 | 04:29 PM
LGshow19's Avatar
There you go.. Another Evom question anwsered..
Old May 31, 2010 | 04:32 PM
boostinggg's Avatar
just bought 8 psi spring thanks everyone
Old May 31, 2010 | 04:33 PM
yahh's Avatar
No problem.
