What else do I need to install FPBlack for MAX PWR on 93
I also agree after switching the XS Power the same as the Turbo XS FMIC I gained allot more power due to mainly less heat soak and also it was allot better in breathing. The ETS Kit with the 3" UICP would be great for you especially if you do a Ported TB or even upgrade the Intake Mani. Also listen to Rich he is very knowledgeable in this area and stuff.
the so called exotic manifolds works price is not a concern if your trying to make power. SOME of use spent less then 1k and are getting all the gains thats where knowing the right people helps for sure. broham i am going to give you more food for thought i pmed you infomation
rich,
I get what you mean man. Did you tune your black yet, I remember you said you haven't tuned it properly yet.
I'm working on it. EGTs are at 900c at 7800 rpm at only 25 psi on 93, so I'm working on bringing those down with water injection before boosting any higher. I'm not a drag racer and can't live with those temps for road course stuff. I have an Aquamist kit but just haven't used it for a couple of years, so it needs some setup/tweaking for my current setup. I'm thinking I wouldn't have this problem if I were running a T3 kit.
I'm gonna order some more parts this weekend after I get paid.
Bushur double pumper
ets 3.5" IC
injestors not sure what size, remember I only use 93 and meth.
When sending in my fuel pump do I remove the walbro?
For sale turbo xs 3.5" IC best offer
ets 3.5" IC
there was a rather heated thread a lil bit ago regarding ets bar/plate vs buschur garret core. and the garret core put down more gains and did it well. I wouldn't order the 3.5 ets core bar/plate go garret core 3.5 they sell it also. But I'd rather get the one that has been recently tested and that is the buschur street 3.5. There is a review of it in the reviews, nothing but great results. If you're getting a double pumper you are planning to go over 500 wheel on pump. Your IDC will be nice if you get 1200's. I'd select fic bluemax 1250's. You can not go wrong at all. 1000 is more than enough but might as well get the 1250's and scale.
I would skip the ETS 3.5" and go straight for the Buschur 4" Race core. It is more proven and whatever premium you pay over the ETS you will recoup when you sell it. There is a steady demand for Buschur Race FMICs because they have been proven over and over again in datalogged testing. I admit I'm biased toward Buschur stuff, but only because of the hard data coming from many racers on this forum for several years.
Yeah, I comprendo this 10-4. The problem with the larger wheeled stock framed turbos is the relatively restrictive, dinky stock 10.5 turbine housing. If you combine the poor flowing Evo exhaust ports with a restrictive housing then you need bandaid fixes such as Robert Fuller's personal setup with a stroked Evo Black. Where he needs an additional dump valve on the DP to try to lower turbine pressures and cylinder pressures.
