hesitation/bogging, rough idle, cold only
Old Jun 4, 2010 | 02:16 PM
warpspeedwrx's Avatar
Hi fellow evo enthusiast. So i've been having this problem with the car hesitating really bad when the engine is cold. Seems to go away once it warms up. The car basically doesnt rev up when i'm applying the throttle. Feels like its missing. Notice it taking off from a stop when i'm laying into the throttle(part throttle).
It does have hks 272 cams. full exhaust. different intercooler kit, bigger injectors, and hks bov. I have replaced the ignition cables and recirculated the hks bov. No change. Did a boost leak test and found the throttle shaft seals leaking a bit. Running copper ngk bpr7es plugs. front 02 sensor is just replaced recently. It does have a check engine light p0172 too rich. I recirculated the bov and cleared the code hoping it will go away.
Anyone ever had this problem ? Any input appreciated
Old Jun 4, 2010 | 02:26 PM
ev0lution9's Avatar
do you have a tune? you didnt state that you did so that could be a problem and also are your plugs gapped correctly?
Old Jun 4, 2010 | 02:29 PM
Yes it has been tuned. I suspect that its possible its in the tune but i want to make sure its nothing mechanical first. Plugs are gapped to .025". They looked okay.
Old Jun 5, 2010 | 10:29 AM
ev0lution9's Avatar
most people run them gapped at.022 so maybe try that and if that doesnt work it may be the tune..good luck!
Old Jun 5, 2010 | 11:23 AM
Evo8luva's Avatar
Sounds like it needs more tuning. Lots of cammed evo's run like crap when they are cold, especially on stock ecu, but they usually can still drive ok.
lance6161
Jul 20, 2025 05:19 PM
nspyr
26
Jun 20, 2017 02:08 AM
hattackk
Nov 18, 2015 06:15 AM
evo10fanatic33
Mar 8, 2013 09:18 AM
korizmo
Apr 27, 2012 11:41 AM
