greddy type s prob
Old Nov 14, 2003 | 12:11 PM
evo 8 ya's Avatar
greddy type s prob
Anybody know how to rought the smaller nipple vac line from the bov to keep the engine from stumbling.
thanks
Old Nov 14, 2003 | 01:42 PM
evo 8 ya's Avatar
bump that
Old Dec 21, 2003 | 09:52 PM
umiami80's Avatar
Its not the nipple you need to remove one of the springs, it is too tight, does not open, and cause compressor surge.
Old Dec 21, 2003 | 09:59 PM
Guru_Del's Avatar
remove the smaller spring, umiami is right.
Old Dec 21, 2003 | 10:00 PM
YellowFever's Avatar
i love nipples from huge breasts .. but anywho....if you cant get the problem fixed then bring it to ur mechannic
Old Dec 22, 2003 | 03:30 AM
FoRk's Avatar
i hope you dont mean you have both the nipples going to your intake mani... you should only have the top one going there and the bottom one left untouched. because if there both going to the mani then you better be looking into a new turbo
Old Dec 22, 2003 | 08:57 PM
evo 8 ya's Avatar
it's cool thanx. I took out the smaller spring about a month ago and it works fine
Old Jan 16, 2004 | 06:54 PM
NRG's Avatar
NRG
Acutally the smaller nipple is suppose to go between the turbo and the wastgate actuator.........Or else the spring adjustment would do nothing.....
Old Jan 17, 2004 | 09:46 AM
Coolguy949's Avatar
No, you dont want to do that. Never hook the small nipple to the boost source after the turbo that goes to the WG actuator. You'll get boost fluctuation. Either tap a new boost line or do what road race does, just put the tap right on the flange under the BOV.
Old Jan 17, 2004 | 11:53 AM
NRG's Avatar
NRG
The reason why I said that is because it is told by TUNERS from the DSM community.....And it made sense.....It was told to seat the valve faster and better.........But they also said you DIDN"T HAVE TO do that.......You could simply not plug anything.........
So I was told........
Old Jan 18, 2004 | 09:54 AM
Coolguy949's Avatar
I'm working off my own DSM knowledge from the 95 gst I owned. Boost was all over the place when I tapped the WG line. I called RRE and they dont ever do that.
I'm talking about which line to tap, not whether or not you should connect the smaller nipple. If you're gonna connect teh smaller nipple its a good idea to find another boost source after the turbo or tap your own.
