......just finished clutch install and car wont shift into first?......plz help
.........As the title says y'all.....I just finished installing my ACT XDSS and the cars shifts through all gears but won't enter 1st..... does anybody have any advice or suggestions to help me out?
Will it go into first with the engine not running? If engine is off and it won't go, check you shifter cables/link, maybe it was put together wrong or a cable is bent/kinked... If yes, your wonderful ACT clutch is prolly at fault.
Yes this is exactly whay I'm experiencing....from what I could see I couldn't spot any kinks or bends so maybe I'm lucky enough that my cousin installed them wrong(he helped with install we split up task to speed things up I should of done that task myself......haha) but either way thanks for the advice guys.....I'll keep you guys posted on what more I find out...
TWM Performance
Oct 5, 2012 09:00 AM
BlueoctaneevoX
25
Oct 12, 2011 09:56 AM
