Big trouble in little china
Old Jun 7, 2010 | 08:53 PM
dambikeracer's Avatar
Tonight I was tuning my car for the drag strip by doing a 1/4 mile dyno pull. So I used the two step to build about 15 PSI with the two step, dropped the clutch and that was all she wrote. The wheels turned a few turns and came to a stop. I thought the car popped out of gear but something went wrong, really wrong!
So I can put it into gear, it goes into gear smooth, shifts fine, the speedometer is still working, but the wheels are not moving... WTF!!! So I've talked to a few different people and here are the ideas they have come up with, problem could be:
1. Blown front diff in the T-case
2. Blown clutch pack in the T-case (06 ACD)
3. Front Input Shaft popped out
4. Blown rear end
5. Broken center diff in the tranny
Drained the fluid in the t-case and the tranny and both seemed good. There were some shavings in the new tranny but nothing big. T-case fluid was perfect, no shavings of any kind (Shep build with stock MR center diff)
SOOOOO WTF could it be? need a quick fix to run the car on Wednesday, PLEASE HELP!
Old Jun 7, 2010 | 09:06 PM
sparky's Avatar
Sorry to hear about your drivetrain woes, dude
Old Jun 7, 2010 | 09:27 PM
chin0's Avatar
So you dumped the clutch on the roller?
Old Jun 7, 2010 | 09:36 PM
Yep, that what it's set up for, or so I'm told? Other wise why would Mustang build it with that option?
Old Jun 7, 2010 | 09:43 PM
So if the axle pops out, does it cut power to all the wheels?
Old Jun 7, 2010 | 09:48 PM
ElectrIX Blue's Avatar
Dang, sorry to hear this happen to ya....Hope you get this situation taken care ASAP
Old Jun 7, 2010 | 10:23 PM
Talked to Kevin at Jacks transmission (working late) he told me that it is either the Center diff in the tranny or the front diff in the tcase. I really hope it's the front diff for goodness sake! Easier fix!
Old Jun 8, 2010 | 10:42 AM
CO_VR4's Avatar
Sorry to hear that. Hope you get it fixed soon and reasonable in cost
Old Jun 8, 2010 | 10:59 AM
PATRICK B.'s Avatar
WOW that is a bummer that it let go on the dyno but it may have saved you a costly tow from the track at least?
I posted up to find out what it ends up to be.........time to start turning wrenches!
Old Jun 8, 2010 | 11:39 AM
iicemanr6's Avatar
if the axle popped out you would have fluid leak out but would not stop the others from spinning
Old Jun 8, 2010 | 12:12 PM
dpalo's Avatar
damn t-case
Old Jun 8, 2010 | 12:38 PM
20gmr's Avatar
make sure the transfer case input shafts are snapped in the whole way. I am pretty sure the car would not move with one axle disconnected. In my driveway my car picks a wheel up because of th egrade and I have almost gotten stuck because it just sends all the power to the wheel thats 2 inches above the ground.
Old Jun 8, 2010 | 11:50 PM
Blown Tranny and Tcase!!! FU** launching your car on the Dyno! I was misled to think it could not hurt the car and this is what happened. It's a brand new built tranny and Shep tase, just look at what happened. Guess it's down time for the Evo!
Old Jun 8, 2010 | 11:54 PM
Pal215's Avatar
both!!?? that freaking sucks man!
Old Jun 9, 2010 | 12:29 AM
italianevo88's Avatar
Wow thats a rediculous amount of damage. looks like I wont be attempting a dyno launch in this lifetime
