Piston Play...
Piston Play...
was just wondering, on a fully built block..pistons rods crank and all
when the pistons are installed is it ok for them to shift left and right or up and down?
with the block sitting on the stand i can take two fingers and move the piston all around....
i have never had a block with after market pistons in it so i have never seen this.
thanks for all help
thanks for all help
Yes there are tolerances involved.
1) Aluminum Pistons with Steel Rings
2) Steel Liners
Expansion rate is different for each and therefore tolerances are required.
If a reputable engine shop built the motor, they can give you those tolerances.
2) Steel Liners
FS[SouthEast]: 4G63 block & GSC S2 Cams (EVO 9)
TIGERJC
12
Jan 7, 2016 09:10 PM
VIIIdriver
14
Dec 12, 2012 01:46 PM
