help goin g lean !!!!
Old Jun 11, 2010 | 06:37 PM
sidtheretard's Avatar
my car started goin lean i put in new fuel pumps new meth pump and control box new fuel regulator no matter what i do it still goes lean anyone know what this could be????
Old Jun 11, 2010 | 06:46 PM
Bggstin's Avatar
What wideband are you using?
Is the pump coming on, for sure?
Does it read normally at idle and partial throttle? Is this only at WOT that it goes lean?
I have alot of other questions but I'll start with that.
I've had issues with fuel pumps, pump not turning on, vacuum line coming off of the fuel pressure regulator - but you seem to have covered this already.
Old Jun 11, 2010 | 08:13 PM
aem wideband and ya the pump comes on for sure its sucking down the alcohol .its fine normal driving and idle it does it on spool up im not going wot with 13 air fuels... idk what it is ive tried everything and it breaks up now but plugs are new coild are new theres no knock battery voltage is up injectors are all working
Old Jun 11, 2010 | 08:23 PM
3gEclipseTurbo's Avatar
Change anything l;ately that would require a retune?
Old Jun 12, 2010 | 08:43 AM
Berts24's Avatar
post some logs if you can
Old Jun 12, 2010 | 03:51 PM
no i would have figured that out it happened out of the blue
Old Jun 14, 2010 | 03:37 PM
bump
Ksay3
Dec 9, 2015 03:26 PM
MrDarkman430
Evo X How Tos / Installations
Nov 28, 2015 09:05 PM
djchopps0013
Jan 29, 2012 02:58 PM
5LEEPERISAH23I
Sep 10, 2011 05:02 PM
sharkm87
Nov 15, 2008 03:59 AM
