11.5 housing.
Old Jun 16, 2010 | 11:33 PM
burnzy's Avatar
11.5 housing.
anyone seen this, 11.5 turbine housing, any thoughts on performance gains/losses?
Old Jun 17, 2010 | 12:05 AM
3gEclipseTurbo's Avatar
Link?
Old Jun 17, 2010 | 12:42 AM
EvolutinIX's Avatar
Originally Posted by 3gEclipseTurbo
Link?
I'm with him.
Old Jun 17, 2010 | 01:08 AM
revvin9k's Avatar
Someone posted this before.....IIRC it was just a worked over 10.5?
Old Jun 17, 2010 | 01:44 AM
So why not just say ported 10.5? Or does it just sound better to say you have a 11.5 hotside?
Old Jun 17, 2010 | 03:03 AM
bbyevo8u's Avatar
theres a 10.8 not a 11.5
Old Jun 17, 2010 | 03:07 AM
MR. EVO MR's Avatar
hey im calling my ported hotside an 11.5 for now on
not
Old Jun 17, 2010 | 05:59 AM
JakeTheVIII's Avatar
Probably much like moving from the 9.8 to the 10.5, not really noticeable.
Old Jun 18, 2010 | 09:49 PM
Slo_crx1's Avatar
The 9.8/10.5cm^2 refers to the area ratio (or a/r) of the turbine housing, so in order for the size to increase to say an 11.8cm^2 that means the area ratio would physically have to change. Porting alone won't raise the a/r, it would have to be re-cast. Do a quick search on area ratio to see what I mean.
Old Jun 18, 2010 | 10:08 PM
sparky's Avatar
Originally Posted by Slo_crx1
.....Porting alone won't raise the a/r, it would have to be re-cast....
By contrast to your opinion, I have concluded that porting could, in fact, under certain circumstances alter turbine housing A/R. Area can be altered, and radial distance between shaft axial center and the scroll's cross sectional centerline can be altered as well.
Old Jun 19, 2010 | 03:28 AM
twista's Avatar
http://cgi.ebay.com/ebaymotors/Turbi...Q5fAccessories
I'm unsure how they have calculated it but i doubt it truly is 11.5.
Old Jun 19, 2010 | 07:34 AM
COL Knock's Avatar
You can alter it by doing that for sure, by making it worse.
Old Jun 19, 2010 | 08:43 AM
nightwalker's Avatar
It's interesting. I wonder if it really is a 11.5 housing.
Old Jun 19, 2010 | 08:47 AM
Kasey's Avatar
By the numbers on the housing its a new 10.5. The funny thing is it has all the mitsu numbers still on it.
Slo_crx1's Avatar
It could to some degree, but not in large enough amounts. The biggest problem would be the thickness of the casting after you port it to achieve any major a/r changes as these turbine housings aren't especially thick to begin with in some spots. You would risk cracking the housing if the walls became too thin.
Edit* I also checked that link that was posted, it states the housing is for a TD06 wheel so the only assumption I can make would be that it's machined larger to fit the TD06 wheel and in which case the standard stock Evo TD05HR wheel wouldn't fit right.
