Not holding boost very well??
Old Jun 19, 2010 | 11:19 AM
k20toEVO's Avatar
Old Jun 19, 2010 | 11:34 AM
Svendiesel's Avatar
Stock bov? Ditch it. They suck period. I dont get how some people keep them on their cars. I replaced mine with a Forge RS and it made all the difference.
Old Jun 19, 2010 | 05:20 PM
k20toEVO's Avatar
You think the 9 bov isn't strong enough to hold the pressure??
Old Jun 19, 2010 | 06:27 PM
gsrboi80's Avatar
A boost leak test will tell you if it is leaking. Mine crushed slightly holds 30 psi everytime I test it
Old Jun 19, 2010 | 06:32 PM
SLO-EVO's Avatar
It is either the BOV or you have a boost leak...
Old Jun 19, 2010 | 06:38 PM
TurboTim06's Avatar
check all vacuum hoses...i had the same problem happen to me a few weeks ago and my vacuum hose going to my BOV had chafed causing a very small hole...fixed the hose and boost was holding perfectly
Old Jun 19, 2010 | 07:22 PM
k20toEVO's Avatar
ok cool ill check it out turbotim06 did u crush ur bov?
Old Jun 19, 2010 | 07:29 PM
TurboTim06's Avatar
yes i crushed it slightly and holds 24-25psi with no problems...once i up the boost more ill prolly invest in an aftermarket one tho
Old Jun 19, 2010 | 08:03 PM
Tribal's Avatar
yeah definately check for leaks
Old Jun 21, 2010 | 03:13 AM
evoyrrah's Avatar
howd u go mate? find the problem?
Old Jun 21, 2010 | 09:05 AM
evoozzie73's Avatar
deff sounds like a leak somewhere might be small check ur injector rings to i had a slight leak from one of them being bad. also i would deff crush ur bov holds boost alot better. gl man
Old Jun 21, 2010 | 09:12 AM
SyZyGy1394's Avatar
Although it might not be much, but check your throttle body shaft seals. Tested and mine leaked like a ****. Ordering the seals today...
Old Jun 21, 2010 | 12:18 PM
k20toEVO's Avatar
I ordered a forge RS BOV should be here in 2 days. I went out and bought all T bolt clamps for every damn pipe. lol, Didnt see anything with the lines. Ill keep ya updated!
Old Jun 28, 2010 | 09:45 PM
hanahawaiian's Avatar
Last time i ran 11.92...
Old Jun 28, 2010 | 09:46 PM
still have Cam? or you removed? it cosworth M3 280/272
