Airtrek Turbo-R
Old Nov 16, 2003 | 08:38 PM
airtreking's Avatar
Airtrek Turbo-R
greetings masters of the street I drive a mitsubishi airtrek turbo which has a 4G63 engine similar to the ones in the latest evo's. Differences are:
- Top-mounted Intercooler ( really makes the engine bay hot)
- Smaller Turbine (not sure of the code)
- Lower compression pistons 8.5:1 as compared to 8.8:1 for the evos
-automatic transmisson only... INVECS II Sport Mode 5-Speed Automatic simmilar to the evo 7 gta...
I dont know if the injectors and the fuel pump is the same but i wil find out...
the car is pumping out 240bhp (engine) and 343nm of torque @ 2500rpm (because of the smaller turbine) and loses breath after 5500rpm.. 1 bar boost about 14psi)
transmisson loss from the engine to the wheels is a very frustrating 36%... so the wheel figures are much less...
I seek for your expertise and advise on how to get this up to a daily driving friendly reliable 300 whp with about 450-500nm of torque @ 2500-3000 rpm because of the auto tranny
so far my performance mods include:
- cat-delete
- hks open airfilter with heat shield(custom)
- hks evc
- hks exhaust (only muffler as recommended by hks... apparently the turbine and auto tranny combo doesn't like anything other then the stock pipe diameters... makes it lose its bottom end... )
These are the mods i have in mind to achieve this:
- walbro 255lph fuel pump
- 264/264 hks cam set
- TD05HRA-16G6 (titanium turbine impeller)
- up boost to about 1.3 bar (18 psi)
- hks oil cooler
- then after the turbine swap get a larger turbo back exhaust...
maybe also:
- larger injectors 660cc
- engine management (f-con)
what else do you recommend or should i include other things to maintain reliability?? PLEASE
Keep up the good work guys!!
Old Nov 16, 2003 | 08:46 PM
eldanoloco's Avatar
Post some pictures.
Old Nov 16, 2003 | 09:19 PM
GotBoost25psi's Avatar
fmic????
Old Nov 16, 2003 | 11:00 PM
Crufty Dusty's Avatar
Are you in Singapore? Go have a talk with GR, there's an ATR with FCon V Pro that Lester says is giving the local Cayenne owners nightmares.
BTW it might be a good idea to do a brake conversion before increasing power. IIRC ATR is on discs-drums setup....
Old Nov 17, 2003 | 06:37 AM
FlySi's Avatar
Old Nov 17, 2003 | 06:47 AM
1QWKEVO's Avatar
ahaah man that car is awsome, US gets all the bunk cars
Old Nov 17, 2003 | 07:21 AM
Fireball's Avatar
Picture an Outlander with a 4g63 w/ a top mount intercooler on it.
That's the Airtrek.
Old Nov 17, 2003 | 04:42 PM
FlySi's Avatar
That's the Airtrek.
or you could just look at the pictures that i posted of it.
Old Nov 17, 2003 | 04:50 PM
underdog's Avatar
Here are some more pics of this rare beast:
http://turbomirage.phpwebhosting.com...c/airtek_turbo
Old Nov 17, 2003 | 05:20 PM
propellerhead's Avatar
I think you're going to have to seriously consider a larger IC, prolly front mounted. Maybe a liquid to air?
Gosh, the dudes that designed the Lancer interior need to go learn a thing or two from the dudes that designed the interior of the Airtrek.
Old Nov 17, 2003 | 05:38 PM
Carlo_Scuderia's Avatar
that i/c definately looks like it needs to upgraded.
Old Nov 17, 2003 | 07:35 PM
holy crap that is freaking bad!!! why cant we get a evo powered suv????? that is awesome!
Old Nov 18, 2003 | 05:21 AM
gunzo's Avatar
Re: Airtrek Turbo-R
Originally posted by airtreking
- Smaller Turbine (not sure of the code) TD04-14
STOCK BOOST IS 0.6 BAR
You WILL break the transmission at 450NM (~42KgM)
You don't lose bottom ends on turbos with exhaust upgrades.. the NA principle of back pressure for turbocharge cars no longer applies here
You cannot get the power you want with 1.3bar on that engine. You need at least 1.5 bar for the torque level.. with the 16G, you're going to lose more bottom end..
Have a spare engine around in case..
Old Nov 18, 2003 | 06:32 AM
blueyzfr6's Avatar
specs
Where can I find the 1/4 mile, 0-60, top speed etc... Also does anybody know where I can get a brochure mailed to me? I'll Pay. I sell Mitsubishi's and our Mitsu managers don't know anything about the Airtrek, and he was saying they were thinking about putting a V6 in the Outlander... WHY? The Airtrek is the same thing.
Old Nov 18, 2003 | 06:49 AM
gunzo's Avatar
Re: specs
http://www.xtreme-uk.net/Xtreme-AirTrekTurboR.pdf
have fun
