Replaced PS pump now I have no PS at all
with my old pump i had no power steering at idle but it would work fine on the move so i figure my pump is starting to go out and only pushed enough fluid with the RPMs up. i swapped in a different pump and now i have no power steering at all. i have tried several methods for bleeding the system since it seems like everyone i talk to has a different method. i have been assured that the pump i put in works fine so is it possible there is still just air trapped in the system? i don't have any more bubbles coming out of the reservoir but should i keep going through the bleeding procedure and eventually my PS will just start working? this thing sucks to drive with no PS and i am leaving friday for a week long trip 14 hours north
thanks for all the help guys, i figured out the problem. stupid human error. the pulley shaft in the pump i bought was bent during shipping so i swapped mine into the new pump...when i did i missed one key step putting it back together. there is a small metal dowel pin that goes through the hole circled below that needs to seat into the bottom part of the pump. i had the dowel through the hole but not seated properly when i reassembled it. i got lucky when i took it back apart and noticed my mistake.
mattsrbu
Evo X How Tos / Installations
Nov 2, 2016 10:04 PM
silentsniper605
15
Oct 14, 2015 05:33 AM
