Data results with some mixed parts.....
Old Jul 6, 2010 | 10:45 AM
  #46
Kracka's Avatar
Below is my Perrin FMIC data. Ambient temp was in the low 70's this day. I believe this was a 4th gear pull but it might have been 3rd. Stock turbo, pump gas, 26psi peak. Blue = MAF temp reading, purple = intake manifold temp reading (GM AIT sensor).
Old Jul 6, 2010 | 11:23 AM
  #47
xhammerx's Avatar
yep FMIC is in perfect condition, never ran in snow. so im preety sure of theres no corrosion....and im sure of theres is no oil in the cooler, cause i have never hooked the vent hooked up.
Old Jul 6, 2010 | 11:36 AM
  #48
David Buschur's Avatar
Kracka, next time you do a run like that get the AIT's stable before doing a log. On the dyno I always drop the AIT's back to where they are stable and then start the run. Starting at 100 degrees, cruising/boosting and getting airflow to drop the temps and then watch them rise again just isn't a great way to log. Just saying....
Old Jul 6, 2010 | 11:46 AM
  #49
Kracka's Avatar
Unfortunately I've since sold my IX so I can't perform the test again. This was a log from the street though, not a dyno session, it was logged doing a pull up a long freeway entrance ramp. I feel it shows the Perrin's cooling ability pretty effectively though since MAT's only varied by about 7 degrees F throughout the entire pull and were almost always cooler than the intake air. The MAF and MAT always read dead-on to the degree with the engine off and cool so I feel they're an accurate comparison.
Old Jul 6, 2010 | 11:51 AM
  #50
raiceboi697's Avatar
i only gained 3 degrees on my ETC 3.5 IC on a full pass at the track, and from what i can see the design on those is very very similar to the BR IC... maybe the perrin unit is just not that efficent and they should look at the design. Marco did the same with his intake manifold and the new one is even better then ever.
Old Jul 6, 2010 | 12:12 PM
  #51
victoryred's Avatar
So the owner well be returing and purchasing a buschur race fmic? Did I read that right?
Old Jul 6, 2010 | 12:15 PM
  #52
GG06MR's Avatar
Yep. Post #4 on the 1st page of the thread.
Old Jul 6, 2010 | 02:28 PM
  #53
03whitegsr's Avatar
Originally Posted by PERRIN_Jeff
Now in defense or DB and their tuning, which is very well known and known to be top notch, maybe there is something else going on. Meaning while his temp readings could be wrong or not fast acting enough, its probably consistent from car to car. And now something is different with this car. Its possible that since this customer is in an area where the roads are salted and there is more corrosion going on from the winter, its possible that the FMIC is really corroded! I have seen some of our old raw cores come back fuzzy from this. Maybe this is the case here, which would really mess up the efficiency of the core.
Or maybe the IC is full of oil from too much blow by or bad turbo?? I would assume these things were check when the old FMIC came off for the new one.
I wasn't saying anything bad at all so there isn't much need to defend anything.
I was just saying the results that David usually sees is amazing to me since numerous others see very different results from my area using the same core. I think it shows that results can vary greatly depending on setup and ambient conditions.
That Garrett core still kicks the crap out of everything else up here, it just won't do what David has seen on the same core in his testing.
Old Jul 6, 2010 | 02:55 PM
  #54
PERRIN_Jeff's Avatar
Originally Posted by SloRice
I'm not trying to take sides Jeff. But take a look at the data log I posted. It has ~5 seconds of data after the pull and the IAT's don't go up. In fact, pretty much right after I let off the gas in 4th gear, the IAT's go back down to "ambient" temperature.
The sampling rate of modern day sensors is pretty quick, so I don't think this is a valid argument.
For sure the sample rate of the sensor is fast, but is the AEM setup to read it fast. I can see by your logs that its really slow acting and really choppy. Maybe you can adjust the sample rate? It looks be like 4hz. Try making that at least 10, but 50 would give you a better picture. Either way you and Dave are using the same sensors.
Also those are super fast 2 second runs. On the Dyno, it could be 12 seconds and for 100% you should see the temp raise higher.
First, this car and I believe just about every car I've ever tuned use the same air temp sensor, the GM/AEM IAT sensor. So the data is atleast comparable and consistent from car to car. Then I'll move onto the end, the intercooler is clean as it's never had the vents hooked into it, car is smoke free, spools correctly and has no power issues, so I'd put money on the turbo being 100%. The FMIC has not been run in the winter, it is new.
Ok, great that does eliminate other weird things going on.
I am sure you are using the exposed element version, but is the thermosistor coated in or bare? I have see the proper temp sensor where the thermosistor is bare, and some where its coated in epoxy. The Expoy coated ones are slow acting compared to these. Or is it possible this is the first time you have use this new Air temp sensor?
As for the engine rpm having nothing to do with, the statement I made, of course depending on boost levels the RPM of the engine will make a difference. What should have been said was turbo shaft RPM on your end instead which is more correct.
Nope not at all, Engine RPM is exactly what i meant.
[QUOTE=davidbuschur;8466685]
Breaking down the compressor chart like you did with RPM written on it is, at best, a guess where the car is running in the map. VE of the engine, boost pressure etc. will change where it actually is. [QUOTE=davidbuschur;8466685]
Its not a best guess at all. I can recalculate a different VE if you like? What VE do you want me to use? I actually errored on low, but now i am thinking higher since it has head and Cams you installed.
I think what I've concluded from this is the FMIC was getting much hotter and the AIT's that I was seeing is acceptable to Perrin. I'm still baffled as to why they were so hot as it's not even in the ball park of acceptable to me and I sure seem to recall the last time I ran one of these FMIC's it was much better than this.
Well with the data being provided, i am not saying its acceptable but trying to explain why its possible the numbers you are seeing.
The key factor to all of this is you only saw 122F at redline on that car. That is perfectly with-in the normal temps i would see. I Think its something else, like you are collecting data differently, or different air temp sensor, or something else. This would explain why your hp numbers are fine.
We talked to the customer today and we are getting the FMIC back so we can eliminate any potential issues with it!
(And thanks to Slorice for the Air Flow Calc from years back), been modding it and using it ever since!
Old Jul 6, 2010 | 03:11 PM
  #55
03whitegsr's Avatar
It doesn't matter how modern something is, if it has a mass, it has a thermal time constant. The larger the mass, the longer the time constant and the slower it reacts. The sampling rate isn't really the issue.
The GM IAT IS NOT a fast sensor by any means and without a doubt, it's missing some of the change in temperature.
Also, you won't see the temperature continue to rise after letting off on a slow sensor. You have stopped putting heat into the sensor and there is no longer enrgy there to cause the temperature to increase. Thermal conductivity is a first order system, it doesn't really have "thermal inertia" that keeps temps climbing once the energy source is removed and you'll never get thermal overshooting like has been suggested.
But as Jeff said, if you use the same sensor, the results will be repeatable and meaningful, just not accurate. If you don’t believe me, hit up Scott or Robert at FP, they have some pretty tiny sensors they use for testing to insure the sensor reacts fast enough.
Old Aug 9, 2010 | 06:11 AM
  #56
Kracka's Avatar
Any updates from this car, David? Did the BR Race FMIC make a difference compared to the Perrin?
David Buschur
413
Dec 28, 2017 09:11 AM
David Buschur
Sep 16, 2013 08:26 AM
David Buschur
Feb 3, 2009 04:22 AM
David Buschur
283
Jun 18, 2008 11:33 AM
David Buschur
58
Feb 29, 2008 04:05 AM
