sigh. a/c problems.
Old Jul 18, 2010 | 11:00 PM
topnotch_EVO's Avatar
Originally Posted by Maxmumboom
my a/c just took a crap on me too. it would only turn on and off intermitently. it turned out that the power wire the plugs into the a/c to cycle the clutch on/off had broked inside the clip. I removed the clip, took it apart and re soldered the wire>>>>now its ice cold at 78k miles if there is to much resistance in the wire, for slight breakage or corrosion, itll do that. I would have never found the problem so fast if I wasnt under the car installing my FP red and cams.
g/l I hope this info helps someone.
I checked all the plugs that are routed to and from the compressor and everything looked fine...I'm about to give up!
I also noticed that my compressor just sounds like it turns off and doesn't come back on till I start moving and the engine gets more air flow. If I pour water on my condenser the air temp drops immediately. When I'm moving the air temps will get all the way down to about 43-45 degrees in 113 degree weather. Once I come to a stop the air temps climb all the way up to 90+ degrees.
Anything come to mind?
Old Jul 20, 2010 | 01:39 PM
I fixed the A/C!!!!!
Unfreakinbelievable...Somehow my condenser fan, the one on the passenger side, was spinning the wrong way and pulling the air towards the front of the car, both should be forcing air towards the rear of the car. I don't know how the f**k that could happen. I rewired the the fan to spin the other way and I have had no problems!!
Old Jul 26, 2010 | 07:04 PM
mrbkkt1's Avatar
... now. my compressor wont shut off. the clutch switch works, because if I pull the sensor by the refrigerant "eye" it will shut off, or if I pull the a/c compressor relay.
even swapped relays. but the compressor never shuts off on it's own. on a side note, it makes super cold a/c but the mileage sucks now.
Old Jul 27, 2010 | 09:19 AM
barneyb's Avatar
The first thing I would do if having AC problems is swap in a new dual pressure switch.
Old Jul 27, 2010 | 10:07 PM
mrbkkt1's Avatar
pressure switch checks out ok....
ANYONE know what would cause the compressor to stay on, even when it's off?
I'm guessing a short somewhere, because the ground in front of the engine bay fuse box gets hot. THe compressor will shut off by pulling either the clutch relay or fuse or unplugging the pressure switch.
Old Jul 28, 2010 | 04:58 PM
mrbkkt1's Avatar
fixed the ground, (retapped, and put a new bolt in) but still no progress. I don't want to take it to the local dealer, because when the ford dealer took over, they got rid of all the mitsu mechanics and now have ford nimcompoops working on the mitsu's.
Old Jul 30, 2010 | 04:28 PM
Berts24's Avatar
I would take it to a local shop that works just on A/C's. So you said you checked a bunch of things but did you check if they're is a constant 12+ volts to the clutch?? If not then I think you clutch stuck
Old Jul 30, 2010 | 05:16 PM
KcEvil8's Avatar
how come nobody bother to hookup the a/c pressure gauge and see what the reading are? the gauge can tell you alot about your a/c system.
Old Jul 31, 2010 | 10:27 PM
mrbkkt1's Avatar
clutch works, because when I unplug H/P switch, or Relay, or fuse, the clutch disengages.
I haven't heard too many good reviews on local auto a/c shops.
I have hooked them up before, and it was working fine....
Here is the kicker, I had forgotten to replug the fan back in, when i replaced the condensor, the a/c had cycled normally before, now that I plugged the fan back in, the a/c doesn't cycle....
on a side note, I took the entire a/c control out today, and noticed... liquid, (maybe coffee?) damage. I cleaned it out, but the compressor still kicks on, when I plug the unit back in. I am going to attempt to see how much a new a/c control unit is from the local stealership on monday. I think that is the problem.
Old Aug 10, 2010 | 04:59 PM
mrbkkt1's Avatar
Fixed!
changed the AC motherboard (MN185123) and everything works fine now.
MisUnderStood
25
Jun 12, 2016 11:10 AM
icrnk
Nov 8, 2013 11:43 AM
pips
For Sale - Miscellaneous Automotive
Nov 22, 2012 07:16 AM
rastamike
Mar 18, 2012 09:03 PM
evokid511
Apr 7, 2010 03:27 PM
