Breaking- up
Breaking- up
Took the car out tonight and everything seemed fine. Until it started cutting out under acceleration, like the spark plugs were bad. Which were changed about 4 weeks ago. This is happening in every gear around 4500-5000rpm's. Any insights or things to have checked would be appreciated. The performance shops around here are sketchy.
I would email dynoflash...but it seems odd that you have this problem all of a sudden. If you haven't had a spark plug failure or your gap was incorrect or a coilpack is going out(never heard of it happening like this). Possibly a bad tank of gas too...so hard to determine over the web
again, log and check with dynoflash rather than internet keyboard warriors
did you try resetting your ecu?
Breaking-up
Not entirley sure on it because Im still in Ghan land and hadnt been able to test it out yet, but Im having the same similar issues with mine and other than the spark plugs I was informed to check for boost leaks.
Everyone was right, it was the spark plugs. I don't know how they could be fouled this bad, the tips were orange. Changed them and it pulls fine now. I'm wondeing if running to much boost could cause that?
addendum
Just to update, in case anyone has similar issues. New plugs helped, but it started miss- firing again. Closed the spark plug gap and then got the PO300 CEL. Then Sunday at an Auto-x, all hell broke loose. Thought the engine was damaged and limped home. Got into shop, and it turns out the ignition coils were bad. Getting them replaced and hoping this finally resolves the problem.
Update: The shop replaced the coil-packs, and I'm still not getting getting voltage to cylinder 1They did a compressiion test and it came out fine. So they have to have another shop more versed on electrical/computer issues trying to diagnose whats going on. If anyone of you have any ideas I'd be glad to hear it and will pass it along. Also, when this is all untangled, I hope to be getting it re-tuned.
