FIC 2150cc OVERKILL?
Old Jul 10, 2010 | 06:18 PM
38six's Avatar
What are you swapping to, wait a minute don't say it, let me guess a 2.4l ?
Old Jul 10, 2010 | 06:20 PM
mullen's Avatar
i recently picked up a 2.4 block but im up in the air between the 2.1 and 2.4 haha good guess though
Old Jul 10, 2010 | 06:33 PM
38six's Avatar
Good luck with your build, you cant go wrong with a 2.4 LR either.
Old Jul 10, 2010 | 06:36 PM
NickieBlaine's Avatar
If your going to eventually go with a big turbo set up, id say go 2.1
If your going to stay with a smaller turbo (black) 2.4 all the way. The black wont have the top end like a bigger turbo, so being able to rev high wouldnt be staying in the powerband. A LR2.4 and black is a perfect set up.... but maybe im biased.
Old Jul 10, 2010 | 06:39 PM
n2oiroc's Avatar
why does everyone forget about a 94mm stroke 2.2L 4g64? best of both worlds!
Old Jul 10, 2010 | 06:50 PM
38six's Avatar
Your right it is the best of both worlds, but most people can't afford it. A forged billet 94 mm crank increases the price of the engine build by an avg of 1500.00.
Old Jul 10, 2010 | 06:59 PM
n2oiroc's Avatar
you dont need a billet crank. an eagle crank is $650 or less and is more than strong enough.
Old Jul 10, 2010 | 07:08 PM
38six's Avatar
No thanks, I wouldn't use a eagle crank, for a high hp build.
Old Jul 10, 2010 | 07:18 PM
n2oiroc's Avatar
maybe i havent looked hard enough, but i havent heard of anyone breaking one. seen quite a few stockers snapped though.
Old Jul 10, 2010 | 07:44 PM
I will be running an eagle crank.
Old Jul 10, 2010 | 10:05 PM
JohnBradley's Avatar
If you are planning run gas and E85, the choices seem to be 1450s or 2150s. Both will also require dual pumps to really max the setup.
Old Jul 10, 2010 | 10:21 PM
mullen's Avatar
i plan to install a buschur double pumper the same time i install the injectors
Old Jul 11, 2010 | 06:51 AM
n2oiroc's Avatar
assuming a double pumper, how much power are the 1,450's safely good for on e85?
Old Jul 11, 2010 | 07:51 PM
Seems as though they should run out somewhere just north of 720whp depending on how much boost it takes to get there. Mikey's combo was at 83-85% at 675 on a scale of 100% so he had some more. His was making the power as a combo of compression and VE as much as anything else. He was at 63 or 64% when he was at 535 so it seems pretty consistent.
EvoScott95
Jun 1, 2015 03:55 PM
aka.ralliart15
May 27, 2008 10:44 PM
Mondo17
41
May 25, 2007 09:36 PM
Dr. SS
17
Apr 17, 2007 06:38 AM
Supa tek
Lancer Tranny/Drivetrain Tech
13
Jun 6, 2005 08:01 PM
