Another quiet exhaust project (BluEVOIX and beyond)
Old Aug 24, 2010 | 07:16 PM
  #91
EVO8LTW's Avatar
Originally Posted by BluEVOIX
I won't know from experience , but I would guess the smoother a cam runs the less likely it will clang and or be loud .
Dennis F had problems with it clanging with Comp 280s. I had those before the Buschur cams and they were relatively smooth idling as cams go. Not too different than HKS 272s and a lot smoother than Kelfords or S2s.
Old Aug 24, 2010 | 08:16 PM
  #92
mifesto's Avatar
actually he did... i looked at his last post and he says he did have some clanging at idle though not major
Old Aug 24, 2010 | 08:52 PM
  #93
R/TErnie's Avatar
MIVEC ftw... if you have mivec you can dial out the lope
Old Sep 20, 2010 | 04:31 PM
  #94
EVO8LTW's Avatar
Old Sep 20, 2010 | 04:49 PM
  #95
shuttlegoose's Avatar
has anyone ever thought of using something like this welded on at the end of the exhaust
http://www.summitracing.com/parts/SUM-630400/
Old Sep 20, 2010 | 05:48 PM
  #96
4DOORGALLOR's Avatar
Rich.... More Pics!
Old Sep 20, 2010 | 05:56 PM
  #97
zac5's Avatar
yea, we need better pictures!
Old Sep 20, 2010 | 06:29 PM
  #98
EVO8LTW's Avatar
Okay, here's one more:
Old Sep 20, 2010 | 07:09 PM
  #99
BluEVOIX's Avatar
Very nice !! Is that boost actuated ? Must be long *** boost line lol . Probably best to use a hard plastic or metal or braided vacuum line to help with response and less expansion . Assuming it's boost actuated .
Old Sep 21, 2010 | 04:15 AM
  #100
EVO8LTW's Avatar
Yes, boost actuated. Thinking of using copper tubing for the line. Not sure whether to route under the car or in the car. Still planning it out.
Old Sep 21, 2010 | 04:33 AM
  #101
RSMike's Avatar
that actuator is neat. it would be cool if you could get one that shut with vacuum, and was open at 1psi or more
Old Nov 18, 2010 | 11:53 PM
  #102
dude's Avatar
This may sound crazy, but has anyone tried a corvette NPP exhaust (well, technically 1/2 of a corvette NPP exhaust)???
The corvette exhaust butterfly is vacuum operated, meaning under vacuum the baffled side is used. Then once boost comes on, the straight pipe side would be used.
I've seen them on ebay for about $350. Now granted, both tips would not fit thru the evo's single cutout in the bumper, but you could cut off the straight pipe tip and put a simple downturn on it.
I'm going to research this a little more, as I don't like the VT rattle.
Old Nov 18, 2010 | 11:58 PM
  #103
dude's Avatar
Here's one on ebay right now for $700, which could be used for 2 evo's. Run a vac line from the engine bay to the solenoid and we're in business.
Now to find the dimensions...
Old Nov 21, 2010 | 09:45 PM
  #104
saxon's Avatar
i have the full works exhaust from the o2 housing to the muffler and its very quiet for a free flowing exhaust, i was actually very surprised
Old Nov 22, 2010 | 04:04 AM
  #105
EVO8LTW's Avatar
I'm really enjoying my boost actuated cutout (pictured above). After a half dozen other setups, this is perfect for me. It's similar in volume to stock but when I hit about 11 psi and above it sounds like an aggressive turboback. Around town my normal driving doesn't hit that boost level unless I want it to, since I have a Black. But since I got it working, whp and boost response jumped way up to. I had to retune and lower boost duty cycle.
