Switching to SD, what intake?
Old Jul 15, 2010 | 08:20 PM
[I.R.A.]_FBi's Avatar
Originally Posted by xmaciek82x
^ in that case I will just make my own with a 45 degree 4" aluminum pipe and a 45 degree coupler.
Should I worry about not having the edged beaded? I don't think anything would pop off since air is being sucked in. Any thoughts?
vacuum
Old Jul 16, 2010 | 06:09 AM
xmaciek82x's Avatar
Originally Posted by travman
I made an adapter with pvc from home depot, mates my 4" filter to my 3" intake....you cant even see it, its behind couplers.
Nice thanks. I will give that a try for a while till I decided what I want to do.
Old Jul 16, 2010 | 05:10 PM
igo4bmx's Avatar
Originally Posted by churchja
Or English Racing's 4" intake... not on their website, but when I asked Aaron at ER said they sell for about $150.
More info HERE
wow a mandrel bent piece of aluminum and filter for $140?!!! lol
Old Jul 16, 2010 | 10:42 PM
JohnBradley's Avatar
MSRP
45* coupler- 67.95
45* polished aluminum leg- 46.95
K&N 4" filter- 66.47
Total- 181.37 MSRP for materials
Cutting it to length, cleaning it up, and fitting it takes about a 1/2 hour. This is $35 based on shop rate. We use quality USA made materials, I am sure if you tried you could make it of something cheaper. God forbid someone make something quality and then try to profit.
Old Jul 16, 2010 | 11:13 PM
italianevo88's Avatar
Originally Posted by JohnBradley
MSRP
45* coupler- 67.95
"God forbid someone make something quality and then try to profit"- well whats the point, my turbo is made out of a hairdryer and my injectors are turkey basters
Old Jul 16, 2010 | 11:17 PM
scheides's Avatar
EvoM Moderator
I just ran my existing buschur intake, it's about 3" ...then ordered up a Perrin foam cone intake for a wrx, sized at 3.125". It fit perfect!
Old Jul 16, 2010 | 11:35 PM
churchja's Avatar
Who said it included a filter? But yes, these intakes from ER are $150... Why LOL? Cusco, HKS, JDM stock replacements go for much more.
Old Jul 17, 2010 | 08:44 AM
Craig King's Avatar
What all is involved in going to speed density?
Old Jul 17, 2010 | 09:48 AM
TeStUdO's Avatar
https://www.evolutionm.net/forums/ec...ched-roms.html
Old Jul 17, 2010 | 10:08 AM
94AWDcoupe's Avatar
heres an intake I made recently. works on both 64mm and 84mm intakes. clamps only needed on turbo and filter. makes for a clean looking intake. silicon doesnt absorb as much heat as aluminum. with fan blowing right on intake this is a factor.
ebay aluminum 3.5 pipe $25
3-3.5 silicon 45 elbow. $25
3.5 elbow $25
ebay 3.5 nine inch filter $25
Old Jul 17, 2010 | 12:04 PM
miragevo's Avatar
Veteran: Navy
Did you silicone or glue the aluminum pipes into the black silicone bends? The reason I ask, is I don't see any clamps in between. I realize the aluminum pipes are inserted rather deeply, but is that enough to hold it together?
Old Jul 17, 2010 | 12:57 PM
94AWDcoupe's Avatar
stays together without sealer or glue. intakes are under vacuum not boost.
Old Jul 18, 2010 | 10:15 AM
xmaciek82x's Avatar
94AWDcoupe that is a really nice looking intake. Thanks for the idea. For now I will run my Perrin intake pipe and get a 3" aluminum pipe along with the Perrin Sti filter (3.1") and see how that works out.
Old Jul 18, 2010 | 01:00 PM
ta ace's Avatar
whats it take to use sd?
Old Jul 18, 2010 | 05:52 PM
xmaciek82x's Avatar
Read this thread. Testudo already posted a link to it couple posts up.
