help with built evo 8 running lean on acceleration
Old Jul 16, 2010 | 09:57 AM
Stroke It's Avatar
Here is my mods
2.3l stroker
272 cams
67trim turbo. Garrett
255 walbro fuel pump
1000cc FICs
The car is running lean on acceleration, problems started after oil change and gas fill. Could it be my fuel pressure regulator?if anyone have any words ideas of wat could be wrong
Old Jul 16, 2010 | 09:59 AM
leonevox's Avatar
nothing to do with oil changed. Did u put e85 in it?
Old Jul 16, 2010 | 10:25 AM
Stroke It's Avatar
No I put 93 pumpgas from BP. He car idles fine but wen u give it gas my wideband shows lean, very lean
Old Jul 16, 2010 | 11:20 AM
KevinD's Avatar
prolly to much salt water in the mix
j/k but i would check for vacuum leaks on the intake (if your running stock ecu with a MAF), check the vacuum hose to the fuel pressure regulator. both can cause the car to run lean
Old Jul 16, 2010 | 01:35 PM
Stroke It's Avatar
Yea I checked those as well I ordered an aftermarket regulator from SBR hope that's it
Old Jul 16, 2010 | 01:40 PM
leonevox's Avatar
put stock regulator on and see
Old Jul 17, 2010 | 05:11 AM
binh's Avatar
how much boost? pretty sure you might need to up your fuel pump needs.
Old Aug 4, 2010 | 10:39 AM
Stroke It's Avatar
replaced fuel pressure regulator, new pump, new 1000 cc injectors , don't kno wat else it could be
Old Aug 4, 2010 | 10:40 AM
Ekoy's Avatar
go to AMS or Strictly modified. Maby you need a tune.
Old Aug 4, 2010 | 11:14 AM
Strictly Modified's Avatar
On very rare occasions you may catch a bad batch of 93. I would try using shell or mobile gas. Or like Kevin D says check the vacuum line to the regulator.
-Cisco
3gevoclipse
14
Sep 21, 2016 07:10 PM
ruarctb
Lancer Troubleshooting
11
Apr 12, 2016 10:59 AM
Bugz
Aug 20, 2010 12:50 PM
RoadSpike
Feb 6, 2008 03:27 AM
Adrenaline718
Jan 2, 2008 12:27 PM
